DaveG
January 18, 2010, 2:10 pm
I know it's bit of a funny question, but would I be right when i say that very single diesel engined car should have a glow plug/pre-heat symbol on the dash ?.
I ask because although it starts up perfectly fine, I cannot see any visible illumination of glow plug activity on the driver display, looking in the central fuse box (behind the glove compartment), I cannot see a signal reference to the glow plug on the diagram, sadly the manual is'nt much use.
Not having a full spec of the car does'nt help, it's a Fusion 2 1.4 tdci with luxury pack 1 (whatever that is ?.)
so 2 questions;
1) surely one of the fuses in the central fuse box relates to the glow plug ?. or could it be the bulb behind the driver display ?.
2), where is the best place (preferably free and online) that i can see a spec sheet for the car ?.
paul-eb
January 18, 2010, 3:23 pm
[quote name='DaveG' post='60664' date='Jan 18 2010, 08:20 PM']I know it's bit of a funny question, but would I be right when i say that very single diesel engined car should have a glow plug/pre-heat symbol on the dash ?.
so 2 questions;
2), where is the best place (preferably free and online) that i can see a spec sheet for the car ?.[/quote]
Hi DaveG,
You may well not have a problem Dave,
I own a Fusion 1.4tdci 57 plate, had no problems like you starting either. I was a little worried also as I never seemed to see the Glow plug light illuminate on the dash, as shown in the handbook, then low and behold the other morning after the car had been subjected to the latest very cold weather -6 to -8c, there it was glowing, a coil shape just for a few seconds. It must only cut in when the weather is very cold, and my car being outside.
May I suggest, if your car is garaged, then maybe it never gets cold enough to need the glow plugs. From what has happened to mine, they must exist. Perhaps someone else may shed some light on it Dave.
DaveG
January 18, 2010, 3:42 pm
[quote name='paul-eb' post='60684' date='Jan 18 2010, 09:33 PM']Hi DaveG,
May I suggest, if your car is garaged, then maybe it never gets cold enough to need the glow plugs. From what has happened to mine, they must exist. Perhaps someone else may shed some light on it Dave.[/quote]
Phew, thanks Paul that's a relief, was getting a bit worried, would make sense though, in a funny but unexplainable kinda way
Weird about the fuse diagram though (no sign of the glow plug fuse at all).
jay1981
January 18, 2010, 7:36 pm
Glowplug light on 1.4TDCI only comes on when it is really cold, around freezing or lower, and only comes on for a few seconds so easy to miss. As for the fuse its probably in another fusebox somewhere.
If the car starts alright then no need to worry!
DaveG
January 26, 2010, 2:03 pm
[quote name='jay1981' post='60722' date='Jan 19 2010, 01:46 AM']Glowplug light on 1.4TDCI only comes on when it is really cold, around freezing or lower, and only comes on for a few seconds so easy to miss. As for the fuse its probably in another fusebox somewhere.
If the car starts alright then no need to worry![/quote]
Can i please clarify something: at start up (turning the key in the ignition), when all the lights come on in the dash, is the glow plug light supposed to come on or not, or does it only come on when it needs to (when very cold), the manual even states "IF" the light comes one wait until it goes out before starting.
Since I've had the car it's only been zero at the coldest.
The next question where behind the battery is the engine fuse box, all i can see is the small square relay box.
DaveG
January 27, 2010, 12:30 pm
[quote name='DaveG' date='26 January 2010 - 08:13 PM' timestamp='1264536200' post='61933']
The question; has been answered, thankfully we had a very cold nice last night and the car was frozen this morning and low and behold, the glow plug light lit for a fraction of a second. So for all you Ford mech's and drivers out there; when the temp's at around zero or warmer you probably won't see the glow plug light even during the light check phase, you should however see it if the temp is below freezing.
Thanks to Jay, you were spot on.
February 19, 2010, 5:48 pm
[quote name='DaveG' date='27 January 2010 - 06:40 PM' timestamp='1264617033' post='62043']
have to admit in any other diesel car the light usually illuminate swith the ignition on for 2 seconds and when really cold a bit longer but that said if there are no starting issues then its obviously just the design of the car
DaveG
February 20, 2010, 2:34 am
[quote name='artscot79' date='19 February 2010 - 11:58 PM' timestamp='1266623285' post='65907']
I agree it's unusual, my Honda Civic's pre-heat/glow plug indicator comes on all the time, regardless of temperature.
My fusion's only appears when it's freezing and obviously stays on for longer when it's very cold. Must be some sort of intelligent pre-heat ?.
February 20, 2010, 12:58 pm
[quote name='DaveG' date='20 February 2010 - 08:44 AM' timestamp='1266654891' post='65934']
crtainly sounds like it as you said no starting issues so they clearly work just another foird only quirk
petesrepairs
February 5, 2012, 5:10 am
I seem to be having this very same issue and I too got the same answers as above. So I wasnt concerned, until today. The temperature here in london has dropped and it snowed last night. So I thought I would go give the car a turn over and see if the glowplug light came on. So I turned it to position 2 all lights except the glowplug light came on. Now I assume the car is cold enough as I have about 5 inches of snow sat on the car. I did try starting the car and it turned over for about a a second and then cut out. I turned the ignition off, on to position 2 again, waited about 5 seconds and then tried to start it again, and this time it turned over and started. so, any new ideas?
February 5, 2012, 9:46 am
The engine not firing first time was probably more to do with the fuel temperarure than the glow plug.
Diesel does get a bit thicker in the cold.
petesrepairs
February 5, 2012, 1:08 pm
[quote name='Stoney871' timestamp='1328456777' post='164876']
Aha, fair enough. Still, however, curious as to why then my ignition coil light still doesnt light up even in the cold (snowing conditions). I did do a dashboard test and on the bulb test it shows the ignition coil lamp as working, but even in freezing conditions (i admit I havent had a thermometer out to test the cold, but snow on the car all night would suggest its minus conditions) it still doesnt appear. Should I just change the plugs and check the connections anyway? or is there another thing to suggest. Also my OBD2 scanner didnt pick up any faults.
Glow Plug problem
