so many people have the stumble on idle after trawling the net i believe ive found a fix.
first pop the hood open and look to the right behind the thermostat housing you will find a rubber hose that goes along and then bends to the rear of the engine now with the bonnet open start the car and go back and check this hos e it will either have collapsed or be pinched and is stopping the air getting through this needs replaced part number is xs4g-6n664-aa its a vacum hose that in the us is no9torious for collapsing apparently ford uk dont see it so the stumble is accepted as the way it is many ion the us have solved the idle by replacing this collapsed hose
location.look to the right and find the thermostat housing now look to the rear of it youll see a thin pipe with a rubber hose attatched follow that hose round to the back of the engine this is the hose it has a bend in it and will likely be soft and spongy it should be hard
removal is a pain but can be done from above the hard part is getting the spring clamp off a set of long nose pliers and some cursing will do the job then gently use a screwdriver to coax the other end off to refit you will need a small hose clampo and some wd40 put the engine side on first and tighten the clamp spray the other end with a dab of wd40 and push it on the pipe gently and youre done mines on order so will be opicking up and doing tomorrow
