jocojohn Posted February 5, 2010 Share Posted February 5, 2010 Hi I have a slight problem with my 52 plate 1.8 Mondeo, but I dont know if its worth the trouble to fix it or just live with it. The problem is the green backlight has gone on the external temperature display within the rev counter dial although it still displays the temp. Has anyone ever fixed this and if so what is involved? Thanks, John Quote Link to comment Share on other sites More sharing options...
fordmann Posted February 5, 2010 Share Posted February 5, 2010 Hi I have a slight problem with my 52 plate 1.8 Mondeo, but I dont know if its worth the trouble to fix it or just live with it. The problem is the green backlight has gone on the external temperature display within the rev counter dial although it still displays the temp. Has anyone ever fixed this and if so what is involved? Thanks, John Hi It's a bit time consuming - about 2 hours but straightforward Here's a guide showing how to replace the dials but the dismantling is the same http://fordwiki.co.uk/index.php/Fitting_Replacement_Dials_-_Mk3 Hope this helps Paul Quote Link to comment Share on other sites More sharing options...
jocojohn Posted February 5, 2010 Author Share Posted February 5, 2010 Hi It's a bit time consuming - about 2 hours but straightforward Here's a guide showing how to replace the dials but the dismantling is the same http://fordwiki.co.uk/index.php/Fitting_Replacement_Dials_-_Mk3 Hope this helps Paul Hi again, Thanks for that, its a very useful guide. I dont suppose you have any idea of the cost of a replacement LCD temp display unit. John Quote Link to comment Share on other sites More sharing options...
mintalkin Posted February 6, 2010 Share Posted February 6, 2010 if the temp display still works it sounds like it just needs a new bulb. Quote Link to comment Share on other sites More sharing options...
jocojohn Posted February 6, 2010 Author Share Posted February 6, 2010 if the temp display still works it sounds like it just needs a new bulb. Hi again, I may be wrong but I didnt think the LCD display used a bulb for the backlight Quote Link to comment Share on other sites More sharing options...
mintalkin Posted February 6, 2010 Share Posted February 6, 2010 from memory i thourght it was controlled through a green diffuser, but after more reserch into this i stand corrected. Quote Link to comment Share on other sites More sharing options...
