Sign in to follow this
john1970
Warning Light
i have 03 focus 1.8 tdci twice now the heater plug warning light has came on the the car cuts out.after 15 mins it will start and run ok has anyone had this problem or know what the problem could be???
indicates a fault either the glow plugs need replaced or theres a fault imn the glow plug system itself ie its not cutting off after 5 minutes start with the basics and replace the plugs first ort take it to ford so you can have it diagnosed as to what the fault is usually the plugs are needing replaced
