Support the club!
Issues After Gasket Repair
1 reply to this topic
#1 3246251196
3246251196
    Member
  • PipPip
  • 18 posts
  • Ford Model: Fiesta Zetec 1.25
Posted 13 July 2008 - 02:21 AM
I got my X Reg Fiesta back recently after having the gasket changed.
Basically, it is running fine and the temperature gauge indicates no problems.
However, it takes a lot less time for the engine to warm up (i.e. within 5 minutes the gauge is up to half way) than what it used to.
Also, having picked up the bad driving habit of knocking it into neutral while crawling toward a red light, I notice that even in neutral, sometimes, the engine will be reving at 2k rather than it dropping; this happens not often, but it is a little concerning.
I do not know if this has something to do with the fans in the engine or not.
Does anyone have any thoughts into this ?
Also: I have noticed, even with the AC off, there is a lot of HOT heat coming out of my vents into the car.
#2 3246251196
3246251196
    Member
  • PipPip
  • 18 posts
Posted 13 July 2008 - 01:06 PM
Been doing a little bit of research on this myself too. I have been looking at similar problems with other Ford cars. When I got the car back, the oil still had water in it until it was all flushed out after a good few miles. For sure, the oil is as it should be now and no water has been taken which is obviously a good sign. I did read something on Throttle Position Sensors though and this could be an issue. Another issue, of course, is not having a great deal of money. I would like to take it to a Ford dealer and get it checked.
My Zetec engine has done about 77k miles, the gasket was sorted about 100 miles ago. I am lucky that I did not totally mess the engine up; I can tell it is not what it used to be though - I hear a rattling-like noise when I floor the accelerator but not as loud as when the problem was happening.
I must say, also, that I have no idea about engines and the mechanics of how cars work (though I would love to). The TPS is located where exactly? And, this could be the issue to the high reving when in neutral (again, this is not a major issue, but it happens SOMETIMES).
Maybe a new ECU is in question? Could an over-heated engine cause an ECU to mess up?
