Sign in to follow this
bobcat
Rear Park Censors Fault
has anyone had any trouble with the rear parking censors on a c-max ghia tdci 2 ltr. the problem is that when in reverse they give a continuous tone for approx 5-6 seconds and then go off. only coming on again if the ignition is turned off and on to reset them. is there any way to check the censors to see if any are faulty.
ford usually hide it behind one of the boot side panels. if you can trace the wires back from the sensors.
