Sign in to follow this
Gareth Roberts
1.6 Petrol (56 Reg) Hesistation Problem
Hello,
I am new to this forum but have been looking at your posts over the last few months.
I have a 56 reg 1.6 petrol ghia. The car has developed a hesistaion while cold always at 2000 rpm is fine awat from 2000 rpm. The car is only a week out of warranty and the local garage have had the car for nearly two weeks now and they have done
Car computer diagnostic - an error code that they have never seen and have no clue what it is!
Temporarly swapped spark plugs, HT leads and coil pack from another car - no change
Complete fuel tank and pump removal check - no problem
3 sets of compression test at different time (first they said it was OK, then not OK (140-155psi range)
Cylinder leakage test!
They have not found the fault but think it may be the conrods are bent (Want over £800 to take apart the engine and check - but no guarantee its the fault!). The car has never been driven in the flood and never hydrolocked. Also why would this problem be only when cold and at a certain engine speed - Surely it would be all the time? The garage cannot anwser any of my questions above which has left me really worried!
Does anyone have any advice on what it could be as I am sure it is not bent conrods?! Many thanks, Gareth
Coilpacks?
they changed the coil pack with one from another car how do they know that it was working? what was the error code all error codes will be stated there arent random ones lying around try and get the code from them and post it here. is this a ford garage or a backstreet mechanic etc conrods i would doubt very highly and compression tests dont just pick and choose it either leaks or it doesnt if you want my opinion the garage doesnt have a clue i would take it elsewhere.
by the sounds of it i would guess coilpack and or ht leads more likely is a sensor wether it be crank sensor or a temperature sensor save youreself 800 quid take it to a ford garage and they will hook it up and see the live data showing them what everythings doing
Thanks for your help so far - today I have had some more info through from the dealer (It is TCH in Derbyshire which is one of the largest ford dealers in the country)
Fault codes
P060A-68 – PCM Internal control module monitoring processor performance.
Compression Test
Cylinder 1 : 125 psi
Cylinder 2 : 125 psi
Cylinder 3 : 130 psi
Cylinder 4 : 125 psi
V C T Angles
Inlet : 7.12 degrees
Exhaust : 13.5 degrees
Cylinder Leakage Test
Cylinder 1 : 12 %
Cylinder 2 : 15 %
Cylinder 3 : 13 %
Cylinder 4 : 10 %
Fuel Pressure
General : 4.02 bar
Thanks for the help. Gareth
Fault codes
Compression Test
V C T Angles
Cylinder 1 : 12 %
Cylinder 2 : 15 %
Cylinder 3 : 13 %
Cylinder 4 : 10 %
Fuel Pressure
General : 4.02 bar
well the compression is within 10psi of a difference which isnt that bad maybe needing the seals replaced
