chris g Posted March 7, 2010 Share Posted March 7, 2010 hi all ,i have a 1999 focus tddi and i have a problem with the steering, for starters its a little heavy, but the main reason i am asking for advice is that as you are driving and try turning to the left there is a slight hesitation before it goes into the turn its a bit hard to explain but any help will be appreciated. Quote Link to comment Share on other sites More sharing options...
artscot79 Posted March 7, 2010 Share Posted March 7, 2010 hi all ,i have a 1999 focus tddi and i have a problem with the steering, for starters its a little heavy, but the main reason i am asking for advice is that as you are driving and try turning to the left there is a slight hesitation before it goes into the turn its a bit hard to explain but any help will be appreciated. check the power steering fluid level and look around the pump area for l;eaks check the obvious such as tyre pressures if all is well it could be the rack Quote Link to comment Share on other sites More sharing options...
chris g Posted March 7, 2010 Author Share Posted March 7, 2010 hi all ,i have a 1999 focus tddi and i have a problem with the steering, for starters its a little heavy, but the main reason i am asking for advice is that as you are driving and try turning to the left there is a slight hesitation before it goes into the turn its a bit hard to explain but any help will be appreciated. fluid and tyre presures are fine where is the p/s pump Quote Link to comment Share on other sites More sharing options...
stef123 Posted March 7, 2010 Share Posted March 7, 2010 i would be checking the strut bearings/mounts. Quote Link to comment Share on other sites More sharing options...
