more power please??
28 replies to this topic
#1 Tom.j
Tom.j
    Newbie
  • Pip
  • 6 posts
  • Ford Model: fiesta
Posted 22 July 2008 - 09:24 PM
ive tried a few differents things but i think putting a set of 15 inch alloys on it has slowed it down dramatically anyone got any ideas how to get my speed back without taking off the alloys ?
#2 vinnyvangough
vinnyvangough
  • Super Mod
  • 2,225 posts
  • Name: Steve
  • Ford Model: Ford Escort RS2000 Mk6 & Mk2 Escort
  • Year: 1996
Posted 22 July 2008 - 10:07 PM
An air filter change and a good service may sort it out for you mate, or upgrade the air filter and a new exhaust system so there is less restriction for it.
And welcome to FOC
#3 Tom.j
Tom.j
    Newbie
  • Pip
  • 6 posts
Posted 23 July 2008 - 09:04 PM
And welcome to FOC
thanks loads just done an oil change got her up a lil u think a K and N woyuld make a difference or 4 point spark plugs ?
another question.. high octane petrol really worth that lil bit extrra a litre?
#4 blakey260
blakey260
    Member
  • PipPip
  • 28 posts
  • Ford Model: Fiesta mk 4 1997
Posted 24 July 2008 - 09:04 PM
K&N will make a difference yeah cause it increases the amount of air that flows into the car, and when theres more air the car requires more fuel meanin u get more power, although the other alternative is to try a mod chip in which goes on the air intake sensor, it sets it to a default so it takes in more air then it needs which does the same as above but increases ur bhp more
#5 Tom.j
Tom.j
    Newbie
  • Pip
  • 6 posts
Posted 24 July 2008 - 09:18 PM
cant chip anything on my car to old no ecu or sensors on it i dont think thanks for your help:)
#6 blakey260
blakey260
    Member
  • PipPip
  • 28 posts
Posted 24 July 2008 - 10:03 PM
ah rite well yeah ur best bet is to go for the performance air filter
#7 vinnyvangough
vinnyvangough
  • Super Mod
  • 2,225 posts
  • Name: Steve
  • Year: 1996
Posted 25 July 2008 - 10:27 PM
Yea go for the air filter and the exhaust. Should free up a bit more power by allowing it to breathe a little better
#8 blakey260
blakey260
    Member
  • PipPip
  • 28 posts
Posted 27 July 2008 - 06:21 PM
hold on u know you said that having 15" alloys on it has slowed it down, are you sure that is hasn't just knocked your speedo, because when you put bigger wheels on the speed ometer shows that your going slower then what it says, for example it says 30mph when ur really doin 25, that might be what your thinkin of when you think its goin slower
#9 racey
racey
    Member
  • PipPip
  • 10 posts
  • Ford Model: fiesta 1.6 freestyle
Posted 27 July 2008 - 09:34 PM
make sure if you put your air filter on that you change for a better exhaust because you can end up spending loads on a filter haveing 1 or 2 more brake but if you upgrade the exhaust youl het more power becasue the exhaust air will have somewhere to escape or youll put preasure on your stock exhaust
#10 Russ
Russ
  • 293 posts
  • Ford Model: Fiesta 1.4i zetec
Posted 02 August 2008 - 03:37 AM
You could try fitting a porsche engine to it :lol: but seriously your speedy could and probably is now reading incorrect due to the change of wheel size!
#11 andyroo89
andyroo89
    Member
  • PipPip
  • 25 posts
  • Ford Model: fiestas
Posted 26 August 2008 - 07:43 AM
could try fitting a 1.4/1.6 cvh exhaust, because of the increase of the bore.
or twin barrel carb from later model.. instead of single barrel.
also ive seen a camshaft kit available on ebay may only be for electronic ignition though.
otherwise some NOS octane booster/engine cleaner available from halfords and a good rag should see a couple more horses
really depends how much you want to spend but id say simple just get the octane booster and a double barrel carb from a scrappy!
andy
#12 mintalkin
mintalkin
  • PipPipPipPipPip
  • 3,321 posts
  • Name: mintalkin
  • Ford Model: mondeo tdci 130
  • Year: 2006
Posted 26 August 2008 - 11:41 AM
basically you need to get more air in and out so any thing on induction or exhaust is going to help, even go for high lift cam and ported manifolds depends what you want to spend
#13 Tom.j
Tom.j
    Newbie
  • Pip
  • 6 posts
Posted 26 August 2008 - 09:33 PM
cheers all ill av to chek my speedo wit a sat nav and will try all the other bits shud be gettin money sooon well payed fri thanks for advice:)
#14 andyroo89
andyroo89
    Member
  • PipPip
  • 25 posts
Posted 27 August 2008 - 04:50 PM
speedos are wrong anyway arent they? above 60mph my sat nav and speedo are at least 3-4 mph out
andy
#15 blakey260
blakey260
    Member
  • PipPip
  • 28 posts
Posted 29 August 2008 - 09:25 PM
andy
yeah ur speedo can go 5% each way from being accurate, where as the sat-nav is 100% accurate, thats why if u get pulled over be te police sayin that ur speedin for example 34mph in a 30 zone and ur sat-nav says that the highest speed you'v done is 30mph then they havnt got a leg to stand on when it comes down to gettin u nicked
