keith43 Posted March 13, 2010 Share Posted March 13, 2010 i had a replacement engine fitted recently. when i picked the car up, it felt different. the revs were running higher than normal, but only whilst it was cold. It now has a whistling / whining noise also, but not immediately. I have a daily run to work of roughly 3 miles. when i pull up to stop. the revs are around 1500 - 2000 and the noise is really loud. this is out of gear? if i blip the throttle, it eventually goes off. As ive mentioned, my car didnt have this problem before the replacement engine was fitted. the garage say that its the charcoal canister! I dont belive them! They have put the engine in with the inlet manifold attached. Could it be this, as they didn't fit my original one back on? A speedy response would be greatly appreciated from anyone with knowledge of what this might be. cheers Keith Quote Link to comment Share on other sites More sharing options...
artscot79 Posted March 13, 2010 Share Posted March 13, 2010 i had a replacement engine fitted recently. when i picked the car up, it felt different. the revs were running higher than normal, but only whilst it was cold. It now has a whistling / whining noise also, but not immediately. I have a daily run to work of roughly 3 miles. when i pull up to stop. the revs are around 1500 - 2000 and the noise is really loud. this is out of gear? if i blip the throttle, it eventually goes off. As ive mentioned, my car didnt have this problem before the replacement engine was fitted. the garage say that its the charcoal canister! I dont belive them! They have put the engine in with the inlet manifold attached. Could it be this, as they didn't fit my original one back on? A speedy response would be greatly appreciated from anyone with knowledge of what this might be. cheers Keith in simple terms no its not the charcoal cannister the high revs could be the idle control valve obviously youre old one didnt do it so a simple swap with that idle control valve would sort it also the throttle position sensor could be sticking Quote Link to comment Share on other sites More sharing options...
keith43 Posted March 13, 2010 Author Share Posted March 13, 2010 in simple terms no its not the charcoal cannister the high revs could be the idle control valve obviously youre old one didnt do it so a simple swap with that idle control valve would sort it also the throttle position sensor could be sticking thanks for the reply. If its the ICV; is it easy to change? Would this make the whistling / whining noise? It only happens when i 1st start the car up. Why would this be? Cheers peeps........ Quote Link to comment Share on other sites More sharing options...
artscot79 Posted March 13, 2010 Share Posted March 13, 2010 thanks for the reply. If its the ICV; is it easy to change? Would this make the whistling / whining noise? It only happens when i 1st start the car up. Why would this be? Cheers peeps........ a whistling noise could be down to air escaping with it idling open the bonnet and see if you can track it down Quote Link to comment Share on other sites More sharing options...
Frankie1973 Posted March 14, 2010 Share Posted March 14, 2010 whining noise could be the auxilary belt... Quote Link to comment Share on other sites More sharing options...
keith43 Posted March 16, 2010 Author Share Posted March 16, 2010 a whistling noise could be down to air escaping with it idling open the bonnet and see if you can track it down Thanks for the advise fella. All sorted. the garage finally saw sense (and my mad eyes!) and changed the ICV. Suprise - suprise, the problem ceased... Quote Link to comment Share on other sites More sharing options...
artscot79 Posted March 16, 2010 Share Posted March 16, 2010 Thanks for the advise fella. All sorted. the garage finally saw sense (and my mad eyes!) and changed the ICV. Suprise - suprise, the problem ceased... another happy ending glad you got it sorted Quote Link to comment Share on other sites More sharing options...
