mick88 Posted March 15, 2010 Share Posted March 15, 2010 Hello all As per title, are the wheel nut's for the alloy's ok to use with the steel spare wheel or are the wheel nut's different for the two type's of wheel Thank's in advance Quote Link to comment Share on other sites More sharing options...
Gazjs Posted March 16, 2010 Share Posted March 16, 2010 I think you are a lot safer to use the nuts off of a steel wheel rather than the alloy nuts. I'm sure I read this before somewhere on the forum. :D Quote Link to comment Share on other sites More sharing options...
Smett72 Posted March 16, 2010 Share Posted March 16, 2010 Hello all As per title, are the wheel nut's for the alloy's ok to use with the steel spare wheel or are the wheel nut's different for the two type's of wheel Thank's in advance I know that my old Mk2 Mondeo used the same bolts for steel and alloy wheels, but they had an alloy shim/washer. The steel and alloy wheels had different size bolt holes, which allowed for steel/steel or alloy/alloy contact depending on the wheels. I don't know whether this is the case for the Fiesta but shouldn't be too difficult to check. But, if your car came specced with a steel spare, then I would have thought that if different bolts were required they would have been provided. Quote Link to comment Share on other sites More sharing options...
mick88 Posted March 16, 2010 Author Share Posted March 16, 2010 Thank's for the replies, my Fiesta came with that tyre sealant so got a new wheel, jack and brace from a scrappy but the car they came from didn't have another spare set of nut's, just wnted to check if the same one's did both wheel's Quote Link to comment Share on other sites More sharing options...
