Brake Drum Removal?
3 replies to this topic
#1 ydna
ydna
    Newbie
  • New Member
  • Pip
  • 2 posts
  • Ford Model: Ka
Posted 17 March 2010 - 08:26 AM
Would someone be kind enough to tell me how to remove the rear brake drum. I flicked the cover off the hub only to find a three piece hub nut with a strange looking locking washer. Do i need to remove these in order to remove the drum or am i barking up the wrong tree? Any help would be much appreciated. Thanks!
Have something to contribute?
#2 delboy
delboy
  • True Ford Enthusiast
  • 534 posts
  • Name: martin
  • Ford Model: c-max ghia 1.8 petrol /ka 1.2 mk2
  • Year: 2004
Posted 18 March 2010 - 05:22 PM
i think it's a 32 mm nut so you need a socket that size.
undo the middle nut & tap the hub off as they bind on so use a hammer to loosen it up
#3 nickdando
nickdando
  • New Member
  • 32 posts
  • Ford Model: VW up!
Posted 18 March 2010 - 11:34 PM
Better to use a wooden mallet as the brake drum is made of cast iron and could shatter if hit with a hammer.
Nick
#4 ydna
ydna
    Newbie
  • New Member
  • Pip
  • 2 posts
  • Ford Model: Ka
Posted 19 March 2010 - 03:35 AM
The hub nut is in three pieces, three thin nuts(about 5 mm thick) held together by a strange looking cage or lockwasher . Do i undo the whole thing as one unit or does the lockwasher have to be removed first? Thanks for the help!
Not what you're looking for?
