pevans91 Posted July 28, 2008 Share Posted July 28, 2008 Hi, i'm new to the forum but seeked help over Google when eventually becoming fed up of the strange problem my Fiesta seems to be having. The car is a 1.25 ltr Encore 1997 model and has only developed the problem within the last month. The problem seems to be that whenever i accelerate by pressing down the gas pedal the car seems to make an audible hissing sound, almost like air is escaping or being sucked into the car. The sound seems to originate from the rear left of the car, where the fuel cap is. I've already tried driving around shortly with the cap off to see if the seal was somehow causing the noise and have also recently changed both the oil and air filter, but still the noise seems to occur. I'm not quite sure if there is a large performance decrease, i'm averaging about 330 miles to a £35 tank of petrol. I'm only a 17 year old new driver with little, but increasing, knowledge of cars (however my step dad and best mate are both fluent). The strange thing is that when revving at a stand still, no hissing or sucking sound can be heard, but when moving even in first or second gear it occurs. However, when i shift into 5th and lightly tap the pedal the sound disapears so it is definitley related to the revvs. Finally, it does seem like the sound can be heard from outside, almost over the engine sound, and sounds ALMOST like a turbo whistle but all the time. Any ideas? Thanks =) Quote Link to comment Share on other sites More sharing options...
salsa Posted July 31, 2008 Share Posted July 31, 2008 Hi, i'm new to the forum but seeked help over Google when eventually becoming fed up of the strange problem my Fiesta seems to be having. The car is a 1.25 ltr Encore 1997 model and has only developed the problem within the last month. The problem seems to be that whenever i accelerate by pressing down the gas pedal the car seems to make an audible hissing sound, almost like air is escaping or being sucked into the car. The sound seems to originate from the rear left of the car, where the fuel cap is. I've already tried driving around shortly with the cap off to see if the seal was somehow causing the noise and have also recently changed both the oil and air filter, but still the noise seems to occur. I'm not quite sure if there is a large performance decrease, i'm averaging about 330 miles to a £35 tank of petrol. I'm only a 17 year old new driver with little, but increasing, knowledge of cars (however my step dad and best mate are both fluent). The strange thing is that when revving at a stand still, no hissing or sucking sound can be heard, but when moving even in first or second gear it occurs. However, when i shift into 5th and lightly tap the pedal the sound disapears so it is definitley related to the revvs. Finally, it does seem like the sound can be heard from outside, almost over the engine sound, and sounds ALMOST like a turbo whistle but all the time. Any ideas? Thanks =) Could it be a hole in the exhaust? Mine had a hissing noise and then one day it sounded like one of those corsas the kids drive around my local morrisons car park. Quote Link to comment Share on other sites More sharing options...
pevans91 Posted July 31, 2008 Author Share Posted July 31, 2008 Could it be a hole in the exhaust? Mine had a hissing noise and then one day it sounded like one of those corsas the kids drive around my local morrisons car park. Hmmm i thought that, but upon revving the engine loudly in neutral you can hear it.... At first i thought it was the exhaust but my step dad thinks differently... It sounds almost like a turbo being put on when accelerating, would it be pretty obvious to notice a hole in the exhaust? Thanks =) Quote Link to comment Share on other sites More sharing options...
salsa Posted August 1, 2008 Share Posted August 1, 2008 Hmmm i thought that, but upon revving the engine loudly in neutral you can hear it.... At first i thought it was the exhaust but my step dad thinks differently... It sounds almost like a turbo being put on when accelerating, would it be pretty obvious to notice a hole in the exhaust?Thanks =) When I had a hole in my exhaust I thought it sounded like water gushing. Infact, I used to sit at traffic lights making the noise happen because it sounded strange. Then it went bertung. Quote Link to comment Share on other sites More sharing options...
Russ Posted August 2, 2008 Share Posted August 2, 2008 Hmmm i thought that, but upon revving the engine loudly in neutral you can hear it.... At first i thought it was the exhaust but my step dad thinks differently... It sounds almost like a turbo being put on when accelerating, would it be pretty obvious to notice a hole in the exhaust?Thanks =) Only a suggestion but have a quick look at the exhaust, what your looking for is small black sooty patches on the exhaust indicating a tiny perforation. If you find any it "could" indicate you`ve a perforated exhaust. ( holes aren't necessarily obvious as exhausts normally start to perforate first )Again it depends where your hearing this sound from? ie. if you hear it from the engine compartment try looking at the exhaust downpipe near the bottom or around the manifold area. if you hear it from outside the car try looking underneath. Quote Link to comment Share on other sites More sharing options...
cougar571 Posted August 4, 2008 Share Posted August 4, 2008 Re-check all your Air Filter connections, it sounds like you're 'sucking' air in, a bit like having a K&N Induction kit. Quote Link to comment Share on other sites More sharing options...
stevesroom Posted August 8, 2008 Share Posted August 8, 2008 is the noise located round the fuel socket or the engine bay ? Quote Link to comment Share on other sites More sharing options...
3246251196 Posted August 11, 2008 Share Posted August 11, 2008 Could it be a hole in the exhaust? Mine had a hissing noise and then one day it sounded like one of those corsas the kids drive around my local morrisons car park. Yeah, I remember getting that. I blew a hole in my exhaust when I pulled away from a red light way to strongly. Blew a hole in the exhaust and, to be honest, it sounded amazing. But it was all sorted within a day. Quote Link to comment Share on other sites More sharing options...
