Focus engine warning light?
#1
Posted 30 July 2008 - 11:04 AM
I'm new on here... as i have jus bought (yesterday) a 2003 focus ST170. (66,630 miles)
Thismorning after starting up, the engine warning light came on, and hasn't turned off since then. The car had a service on monday (2 days ago) where no major work was done. (general wear and tear, as far as I am concerned)
Has anyone had this problem so close to a service? Could it have been something that was done on the car in the service that has caused this, or did they miss something major, or should I just put it down to bad luck and accept something has gone wrong at a bad time (just after purchase!)
I have rung round to ford garages, and the cheapest price to do a diagnostic check with a computer is £60 + VAT!!
If I can put it down to the original garages fault maybe they would see what was wrong for free? I bought the car from guildfor (over an hour away) so I can't 'pop' into the garage that did the work on monday too easily...
I appreciate any advice on the matter!!
thanks
Murray
#2
Posted 30 July 2008 - 08:37 PM
#3
Posted 31 July 2008 - 08:26 AM
#4
Posted 31 July 2008 - 11:04 AM
I thought it was only ford garages that have the computer software to check fords? or maybe i'm being very naive!..
Hi. Try using the cars dashboard diagnostics to get the fault code as follows;
with the ignition off hold down the mileage tripmeter reset button,
start the car(still holding the button) and wait for a few seconds
the word " test " should then appear( now release the button)
each further press of the button with scroll through various gauge/bulb tests, temp, fuel etc.
stop when DTC appears ( diagnostic trouble codes). If any codes are stored they will be displayed, if not, " none " will be displayed.
this may not be as comprehensive as garage equipment, but its free so well worth a try. Even my mechanic mate didnt know of this function. I wonder why Fords dont put this info into the cars handbook
#5
Posted 31 July 2008 - 11:28 AM
wow thanks for the tip john! unfortunately, in my hurried panic i've taken it into the garage thismorning, as it suggests in the owners' book to do so ASAP if this warning light appears.Hi. Try using the cars dashboard diagnostics to get the fault code as follows;
Since yesterday i have heard of 2 of my friends having the same engine warning light in their cars, and both said it was due to spark plug and coil problems... has anyone had similar problems in the engine compartment? what would be the cheapest way to fix these problems?
#6
Posted 02 August 2008 - 06:00 PM
Hi all!
thanks
Murray
#7
Posted 02 August 2008 - 06:10 PM
#8
Posted 04 August 2008 - 01:18 PM
Hi all!
thanks
Murray
Hi just joined today,
Have had same problem with my st170 engine managemaent light on after service they had serviced and changed spark plugs,apparently didn't get a lead back on correctly,they reset fault light no charge.
hope you had some luck.
