Air Con
6 replies to this topic
#1 bottletree
bottletree
  • New Member
  • 219 posts
  • Name: Shane
  • Ford Model: C-max 2.0litre. Ghia EST. 2005
  • Year: 2005
Posted 26 March 2010 - 09:47 PM
Should the air con come on automatic when i switch the engine on? In other cars i owned i pressed the air con button to come on, but in this car i have to press the switch off. Surely it should be in the off position until I decide I want the air con?? :huh:
Have something to contribute?
#2 top banana
top banana
  • New Member
  • 114 posts
  • Ford Model: Fiesta Zetec 2011 in Mars Red
Posted 26 March 2010 - 09:55 PM
Mine only comes on automatically from starting engine if blowers are set to windscreen only. Otherwise I have to manually switch air con on.
Hope this helps for you.
#3 bottletree
bottletree
  • New Member
  • 219 posts
  • Name: Shane
  • Year: 2005
Posted 27 March 2010 - 02:10 PM
I always have the blower on the windscreen one. I will try a different setting and see if it stays off.Cheers for that.
#4 Neil Layton
Neil Layton
    Newbie
  • New Member
  • Pip
  • 1 posts
  • Ford Model: Focus Zetec
Posted 29 May 2010 - 04:54 PM
Hi, newer models of ford focus, you cannot turn the air con off automatically, it is built in to the software, asked several Ford garages and all have said it cannot be turned off.
#5 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 20,660 posts
  • Name: James
  • Year: 2007
Posted 29 May 2010 - 07:17 PM
Yeah, I find on my 55 ZC, the air con comes on if the temperature is set to cold, and, the blower is on blower one or more. don't think it comes on if its on warm.
#6 artscot79
artscot79
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 7,889 posts
  • Name: arthur
  • Year: 2006
Posted 29 May 2010 - 08:48 PM
souns like its normal to me you just have to adjust the dial as said you may also notice that when you start the aircon it blows through the footwell vents first regardless of the setting at least my old vw did this is to prevent any condensation from the vents being blasted into youre face or onto the window
#7 mattie2k10
mattie2k10
    Newbie
  • New Member
  • Pip
  • 6 posts
  • Ford Model: 2006 Ford Focus 1.6tdci
Posted 30 May 2010 - 08:54 AM
Fords have a system called quick clear, if the blowers are set to the windscreen then it will automatically turn on, if you turn the blowers to your face and turn the aircon off, when you turn it back to the windscreen the aircon will automatically turn back on, hope this helps. Matt
Not what you're looking for?
