Vacuum Horse
1 reply to this topic
#1 chris26
chris26
    Member
  • New Member
  • PipPip
  • 28 posts
  • Ford Model: 2000 tddi
Posted 03 April 2010 - 09:37 AM
Hi im replacing my egr valve because mine is stuck open/closed causing the car to loose power. ive heard about replacing the vacuum horse helps as they oftern collapse.how many vacuum pipes need replacing ???? thanks in advance
Have something to contribute?
#2 artscot79
artscot79
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 7,892 posts
  • Name: arthur
  • Year: 2006
Posted 03 April 2010 - 01:03 PM
theres 2 the main one from under the throttle body and a small bend as well if youre getting the parts from ford the guy will show you on the pc the diagram basically the hose connects to a metal pipe then at the other end you have a bend then the pcv valve connects into the top of it
Not what you're looking for?
