Do's And Don'ts Of Diesels
9 replies to this topic
#1 bottletree
bottletree
  • New Member
  • 219 posts
  • Name: Shane
  • Ford Model: C-max 2.0litre. Ghia EST. 2005
  • Year: 2005
Posted 03 April 2010 - 09:17 PM
I have owned 6 cars since passing my driving test in 1996. All of them were petrol engines. This is my first diesel.The one thing i always knew about diesels was to not turn engine over till the glow plug warning light went out.I have recently read on these boards that with this 1.6tdci 06 model i have now you can turn engine over straight away unless of course its below a certain temp outside(minus 1c i believe).
Can anyone shed light on what else would be useful to know about diesels. These particulate filter thingy's sound scary to me and expensive.
My uncle owned diesels all his life and told me his engines never burnt oil. That sounds great to me as with the petrol engines i was forever topping up the oil.
Advice and views welcome from anyone Ta. ;)
Have something to contribute?
#2 cyb
cyb
  • 548 posts
  • Name: Colin
  • Ford Model: fiesta 1.4tdci
  • Year: 2009
Posted 04 April 2010 - 08:43 AM
Ford say you don’t need to wait until the heater light goes out but to be honest when I remember I usually do – its only a second or two.
if you try to set off in 2nd , at say a round-a-bout, you might find it easier to stall than a petrol, nothing wrong just need a little more revs than a similar petrol engine car.
The particulate filter, if you do a lot of short low speed journeys I would take the car for a bit of a blast once a week just to clear out some of the crap.
As for the oil - and as with any car check the level before and after any long runs, just to be safe.
You should find very few differences between a diesel and similar petrol engine cars and your driving style will soon adapt –enjoy the ride (and the extra mpg) :)
#3 bottletree
bottletree
  • New Member
  • 219 posts
  • Name: Shane
  • Year: 2005
Posted 04 April 2010 - 09:27 AM
I found out in the first week or so, me and the Mrs were stalling the car on set off, because you needed the extra revs.I do majority of my journeys about 90% short trips so i will make sure i do give it a blast once in a while.Thats not the first time i have heard that.
I have noticed when travelling at 30 mph the diesel seems to want me to change down cause the speed is not fast enough for the fourth gear. In the petrol doing 30 mph on the flat was fine in fourth, but this diesel seems to need more speed. Probably something to do with the gear ratio i believe.
A friend at work warned me that i should never bump start a diesel if the battery is flat. He said it can damage the engine. Best to use jump leads.I would never have known this in a million years.
Anything else i need to know?
#4 hillmangimp
hillmangimp
  • New Member
  • 138 posts
  • Ford Model: Focus 2.0 TDCI
Posted 04 April 2010 - 02:54 PM
Don't put unleaded in it! Its a good idea to give a diesel a good working through the gears every once in a while (provided the engine is warm and the timing belt isn't due for a change) especially if you do short journeys. I also find with mine that if I try and drive conservatively that mpg isn't that great, however if I am a bit more enthusiastic(!) mpg is better so its about getting a balance.
Also, a lot of diesels have had issues with DMF (Dual mass flywheel) failure which costs hundreds to fix. If the DMF's going to go its going to go, but not riding the clutch for example will help to extend its life. i've also read its good practice to not not let the car run low on fuel (i.e. wait for the fuel light to come on) due to lack of lubrication which can cause problems with fuel pumps (again very expensive). For what is worth i tend to fill mine back up when its down to its last quarter (when possible). Other than that its just about making sure the car is serviced regularly and enjoying the ride.
#5 catch
catch
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 1,305 posts
  • Ford Model: MK2.5 Focus 1.6 Titanium Petrol
  • Year: 2011
Posted 04 April 2010 - 06:40 PM
If your doing 90% short journeys, every three hundred miles at the very least warm it up and give it a 15/20 minute thrashing on a bit of dual carriage way to induce a DPF "regeneration cycle" [burning off the soot clogging up the filter] Don't know if your motor has the instantaneous MPG read out option, my Volvo S40 had. If it does you will see the mpg fall away during the DPF "regeneration cycle"
#6 adrian29
adrian29
    Member
  • New Member
  • PipPip
  • 19 posts
  • Ford Model: focus 1.8dti estate
Posted 11 April 2010 - 02:25 PM
Hi, just wondered if my problem could be as simple as a filter change??? - see my post re Focus breakdown yeterday. The car was previously owned by an old guy only doing short trips, covering apprx 4k mile in the 2 years following its last service in May 08.
Car lost power yesterday and glo plug light flashing, booked into fords tommorrow so will know outcome then, just anxious that it may something expensive connected to fuel pump etc, but hoping it may something as simple a new filter / service?
#7 catch
catch
  • PipPipPipPipPip
  • 1,305 posts
  • Year: 2011
Posted 11 April 2010 - 06:31 PM
I very much doubt you car has a DP filter what year is it?
#8 adrian29
adrian29
    Member
  • New Member
  • PipPip
  • 19 posts
Posted 11 April 2010 - 06:54 PM
mine is W (2000)
#9 stef123
stef123
  • Management
  • 5,759 posts
  • Name: Stef
  • Ford Model: Mondeo ST TDCI
  • Year: 2006
Posted 12 April 2010 - 08:46 AM
there are loads of things i can list here but,
if its a tdci engine, then you dont really need to wait on the plug light going out, but on a cold morning you really should because if not it will struggle to start. (the same goes for any common rail diesel)
dont let a diesel get low on fuel, air bubbles in the fuel line are not what you need and it will cause issues. in a petrol engine if you run out of fuel you just fill it up and then start the engine, with a diesel you need to bleed out any air.
the DPF, what a sh1te idea :lol: if you can get one without this then brilliant. more hassle than its worth IMHO.
should never really bumpstart any modern car. bumpstarting even a petrol car can do damage, think of all that unburnt petrol going in the cat...nice.
#10 catch
catch
  • PipPipPipPipPip
  • 1,305 posts
  • Year: 2011
Posted 12 April 2010 - 10:07 AM
mine is W (2000)
Nope
Not what you're looking for?
