Dtc Codes
17 replies to this topic
#1 coll247
coll247
  • Budding Enthusiast
  • 65 posts
  • Name: colin
  • Ford Model: focus
  • Year: 1999
Posted 07 April 2010 - 09:33 PM
hi can any one tell me how to get rid of dtc codes without a diagnostic machine. is it possible.
Have something to contribute?
#2 DMR
DMR
    Member
  • New Member
  • PipPip
  • 26 posts
  • Ford Model: Focus
Posted 07 April 2010 - 11:02 PM
disconnect ur battery for 15 mins normally works
#3 coll247
coll247
  • 65 posts
  • Name: colin
  • Ford Model: focus
  • Year: 1999
Posted 08 April 2010 - 04:11 PM
tried that it didn,t work.code says(9202 fuel pump module circuit open)an (d262 missing speed, tacho,engine temp,or dometer count). but car is running fine. bean to a garage and add they said there are no codes in the ecu.so how can i remove them.
#4 DMR
DMR
    Member
  • New Member
  • PipPip
  • 26 posts
  • Ford Model: Focus
Posted 08 April 2010 - 04:47 PM
how can there be no codes if you are getting codes? are u reading the codes with a code reader or the in dash trick
#5 coll247
coll247
  • 65 posts
  • Name: colin
  • Ford Model: focus
  • Year: 1999
Posted 08 April 2010 - 05:21 PM
the dash trick
#6 DMR
DMR
    Member
  • New Member
  • PipPip
  • 26 posts
  • Ford Model: Focus
Posted 08 April 2010 - 09:40 PM
well thats the fuel sender unit, could be on it's way out, do u ever find that your fuel gauge reads lower than it should, i.e it say u have a quarter of a tank when u know it should have a half full tank? or does it take upto 30 seconds from when u turn on the ignition for it to register?
I have just finished replacing my fuel pump/sender unit today, pain in the !Removed! !Removed!
#7 DMR
DMR
    Member
  • New Member
  • PipPip
  • 26 posts
  • Ford Model: Focus
Posted 08 April 2010 - 09:43 PM
what car u got?
#8 coll247
coll247
  • 65 posts
  • Name: colin
  • Ford Model: focus
  • Year: 1999
Posted 08 April 2010 - 10:55 PM
hi the fuel gauge is reading ok.ever thing seems ok. just got them codes when i do the dash trick
#9 coll247
coll247
  • 65 posts
  • Name: colin
  • Ford Model: focus
  • Year: 1999
Posted 08 April 2010 - 10:59 PM
what car u got?
hi its a 1999 T reg 1.6 LX 16 valve.
#10 DMR
DMR
    Member
  • New Member
  • PipPip
  • 26 posts
  • Ford Model: Focus
Posted 09 April 2010 - 08:34 AM
long shot but how much fuel do u have in the tank when u do the in dash test? if the level is low then it might just be because of the try half a tank full see if it comes up with it then, might wanna try disconnecting the battery first for 15. if u have plenty of fuel when u tried it then i don't know, codes generally don't appair for no reason esp if they wont go away
#11 artscot79
artscot79
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 7,887 posts
  • Name: arthur
  • Year: 2006
Posted 09 April 2010 - 02:04 PM
some codes though cleared will stay on the dash until the car has completed a preset amount of driving ie a month without the fault reoccuring which is what sounds like is happening for example if you got a low battery code and replaced the battery it will still show on the dash till the car has been turned on and off so many times and completed so many miles
#12 coll247
coll247
  • 65 posts
  • Name: colin
  • Ford Model: focus
  • Year: 1999
Posted 09 April 2010 - 03:05 PM
tryed it with a full tank half a tank and a low tank still the same i,ll try it agane when i fill up
#13 coll247
coll247
  • 65 posts
  • Name: colin
  • Ford Model: focus
  • Year: 1999
Posted 09 April 2010 - 03:07 PM
i,ll just keep trying it when i fill up.
#14 artscot79
artscot79
  • PipPipPipPipPip
  • 7,887 posts
  • Name: arthur
  • Year: 2006
Posted 09 April 2010 - 06:30 PM
give it a few weeks and see if normal driving clears the ciode you might be surprised
#15 coll247
coll247
  • 65 posts
  • Name: colin
  • Ford Model: focus
  • Year: 1999
Posted 09 April 2010 - 10:14 PM
iv,e had the car for 2 month and is still there. but car is running fine. just want to know if i can remove the code my self.
Not what you're looking for?
