Sign in to follow this
Leemond80
Heated Windscreen Issues
Hi All,
One side (my fekin side) of the windscreen doesn't demist with the electric demister. There is a perfect line down the middle where the passenger side is fine and mine is still misty. Is there a fuse to replace for this as i heard Mk2s have a fuse for each side?
If so i would really appreciate any help as to where i can find the little git!
Cheers in advance :)
Hi All,
Two fuses indeed - your manual should show you where these are (sorry to be vague; I'm not sure without looking at mine!)
Two fuses 40amp in the main fuse box, they should be by the relay, the main fuse box is under the bonnet.
