Zetec 1.4 - coil pack - is this it ?
#1
Posted 07 August 2008 - 04:24 PM
"Coil pack" - Ford want £100 but I've found this, part number is identical to the one of the car...
is this what the Dealer meant by "Coil Pack" or is there something else to it ?
http://www.cranksens...earchStr=PC6280
Any help much appreciated
simon
#2
Posted 15 August 2008 - 07:56 PM
HiHave problems with rough idling & a lit engine management light. I've changed the plugs & ignition leads but the problem remains & the guy at Ford told me if leads/plugs don't work that its the
simon
That is the coil pack.
Good luck!
#3
Posted 15 August 2008 - 09:14 PM
Hi
Good luck!
Thanks for the reply....
problems solved...fitted new coil pack + ignition leads + spark plugs, disconnected battery for 30minutes & engine warning light fault cleared too !!!
Just on the coil pack don't get the Ford one..£110, I paid £40 from a local motor spares shop
simon
#4
Posted 16 August 2008 - 05:39 PM
my mate has a fiesta (1.4 zetec 2002) and one day it decided to die, i checked it out for him and it all pointed to the coil pack being dead, so as a matter of course new HT's new sparks and new coil all fitted nice and easy, now car will not fire, turns fine but refuses to burst into life.
I have checked leads are good, check sparks and spark guage, all good, all coil pack outleys fire fine, fuel seems to hit the rails fine, only thing i can think of is ecu is telling injectors not to fire since instlling the coil pack.
I noticed you had 30mins of batt discon, is this to reset the ecu and therefore re-energise the injectors???
checked feul pump & filter and the all gd so this is my last option i can think of, o and lambda and crank sensors are all gd.
thanks in advance.
#5
Posted 21 August 2008 - 06:12 PM
Hi, new to this forum but like what i see,
thanks in advance.
Having posted that I'd sorted the problem I'm now not 100% sure I have....
To recap on the problem..
Fiesta 1.4 2004
It suddenly started run rough & engine warning light came on, called RAC who said it showed a fault on CYL 4. Turned out to be coil failure so I replaced coil/spark plugs & ignition leads & whilst it's much better it now seems slightly hesitant during acceleration sometimes..
my thoughts are maybe the fuel filter or the MAF / Lamba sensor have been affected by the coil failing ?
All advice appreciated
simon
