simonkit Posted August 7, 2008 Share Posted August 7, 2008 Have problems with rough idling & a lit engine management light. I've changed the plugs & ignition leads but the problem remains & the guy at Ford told me if leads/plugs don't work that its the "Coil pack" - Ford want £100 but I've found this, part number is identical to the one of the car... is this what the Dealer meant by "Coil Pack" or is there something else to it ? http://www.cranksensors.net/detailspage.as...earchStr=PC6280 Any help much appreciated simon Quote Link to comment Share on other sites More sharing options...
Isabella Posted August 15, 2008 Share Posted August 15, 2008 Have problems with rough idling & a lit engine management light. I've changed the plugs & ignition leads but the problem remains & the guy at Ford told me if leads/plugs don't work that its the "Coil pack" - Ford want £100 but I've found this, part number is identical to the one of the car... is this what the Dealer meant by "Coil Pack" or is there something else to it ? http://www.cranksensors.net/detailspage.as...earchStr=PC6280 Any help much appreciated simon Hi That is the coil pack. Good luck! Quote Link to comment Share on other sites More sharing options...
simonkit Posted August 15, 2008 Author Share Posted August 15, 2008 HiThat is the coil pack. Good luck! Thanks for the reply.... problems solved...fitted new coil pack + ignition leads + spark plugs, disconnected battery for 30minutes & engine warning light fault cleared too !!! Just on the coil pack don't get the Ford one..£110, I paid £40 from a local motor spares shop simon Quote Link to comment Share on other sites More sharing options...
Zedman Posted August 16, 2008 Share Posted August 16, 2008 Hi, new to this forum but like what i see, my mate has a fiesta (1.4 zetec 2002) and one day it decided to die, i checked it out for him and it all pointed to the coil pack being dead, so as a matter of course new HT's new sparks and new coil all fitted nice and easy, now car will not fire, turns fine but refuses to burst into life. I have checked leads are good, check sparks and spark guage, all good, all coil pack outleys fire fine, fuel seems to hit the rails fine, only thing i can think of is ecu is telling injectors not to fire since instlling the coil pack. I noticed you had 30mins of batt discon, is this to reset the ecu and therefore re-energise the injectors??? checked feul pump & filter and the all gd so this is my last option i can think of, o and lambda and crank sensors are all gd. thanks in advance. Quote Link to comment Share on other sites More sharing options...
simonkit Posted August 21, 2008 Author Share Posted August 21, 2008 Hi, new to this forum but like what i see,my mate has a fiesta (1.4 zetec 2002) and one day it decided to die, i checked it out for him and it all pointed to the coil pack being dead, so as a matter of course new HT's new sparks and new coil all fitted nice and easy, now car will not fire, turns fine but refuses to burst into life. I have checked leads are good, check sparks and spark guage, all good, all coil pack outleys fire fine, fuel seems to hit the rails fine, only thing i can think of is ecu is telling injectors not to fire since instlling the coil pack. I noticed you had 30mins of batt discon, is this to reset the ecu and therefore re-energise the injectors??? checked feul pump & filter and the all gd so this is my last option i can think of, o and lambda and crank sensors are all gd. thanks in advance. Having posted that I'd sorted the problem I'm now not 100% sure I have.... To recap on the problem.. Fiesta 1.4 2004 It suddenly started run rough & engine warning light came on, called RAC who said it showed a fault on CYL 4. Turned out to be coil failure so I replaced coil/spark plugs & ignition leads & whilst it's much better it now seems slightly hesitant during acceleration sometimes.. my thoughts are maybe the fuel filter or the MAF / Lamba sensor have been affected by the coil failing ? All advice appreciated simon Quote Link to comment Share on other sites More sharing options...
Paul mann Posted January 28, 2014 Share Posted January 28, 2014 Hi, new to this forum but like what i see, my mate has a fiesta (1.4 zetec 2002) and one day it decided to die, i checked it out for him and it all pointed to the coil pack being dead, so as a matter of course new HT's new sparks and new coil all fitted nice and easy, now car will not fire, turns fine but refuses to burst into life. I have checked leads are good, check sparks and spark guage, all good, all coil pack outleys fire fine, fuel seems to hit the rails fine, only thing i can think of is ecu is telling injectors not to fire since instlling the coil pack. I noticed you had 30mins of batt discon, is this to reset the ecu and therefore re-energise the injectors??? checked feul pump & filter and the all gd so this is my last option i can think of, o and lambda and crank sensors are all gd. thanks in advance. Quote Link to comment Share on other sites More sharing options...
Paul mann Posted January 28, 2014 Share Posted January 28, 2014 Change plugs but change gap to1 mm not the standard 1.3 mm seems over time the plugs set at 1.3 mm can cause coil failure...you may need to change coil as well....secret given to me by ford mechanic... Worked for me ..good luck Quote Link to comment Share on other sites More sharing options...
