rog99 Posted April 26, 2010 Share Posted April 26, 2010 Hi, I have just been overhauling my rear drum brakes . During this I removed the 4 bolts holding the stub axles. When re-assembling I found that it not clear from the Haynes manual what the correct torque setting for these bolts should be. The only ones that manual quotes is "Rear drum brake backplate/disc shield" at 66nm. Is this the correct one? Thanks Roger Quote Link to comment Share on other sites More sharing options...
stef123 Posted April 26, 2010 Share Posted April 26, 2010 Hi, I have just been overhauling my rear drum brakes . During this I removed the 4 bolts holding the stub axles. When re-assembling I found that it not clear from the Haynes manual what the correct torque setting for these bolts should be. The only ones that manual quotes is "Rear drum brake backplate/disc shield" at 66nm. Is this the correct one? Thanks Roger personally i have never set the torque on these bolts but looking at how haynes reffers to the job and knowing that the backplate is riveted on then i would say 66Nm is correct. Quote Link to comment Share on other sites More sharing options...
rog99 Posted April 26, 2010 Author Share Posted April 26, 2010 I have just looked on my Ford TIS workshop manual disk [that I had forgotten I had ] and that is indeed the correct torque for these bolts. Thanks anyway..... Quote Link to comment Share on other sites More sharing options...
