Which Cleaner Is Best To Be Poured Down In The Tank?
9 replies to this topic
#1 starfield
starfield
  • New Member
  • 171 posts
  • Ford Model: 1.8 zetec, Mark II, petrol (manu 56 reg)
Posted 01 May 2010 - 06:53 PM
I currently have an issue with my vehicle which is under the 'delayed acceleration' topic. I am thinking of poring some cleaner down my tank, what cleaner works? What cleaner does the manufaturer recommends?
Have something to contribute?
#2 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 20,957 posts
  • Name: James
  • Year: 2007
Posted 02 May 2010 - 08:52 AM
Technically they dont recommend any, as it invalidates any warranty that still stands. The best thing to do is treat the tank with "Redex", that will at least give the injectors a quick once over. It really depends on the state of the car overall, and how well serviced it is. as its a Mark 2, unless you have racked up around 80,000 miles, the redex will probably suffice.
Over the longer term, a good service may well come in handy, air, fuel and oil filters, oil, and spark/glow plugs (not sure if yours is P or D), and if it is diesel, and you have done a fair few amount of miles, you may need the DPF clearing through.
Can you give us more info on the car, Mileage, fuel type, age, trim, etc?
#3 hillmangimp
hillmangimp
  • New Member
  • 138 posts
  • Ford Model: Focus 2.0 TDCI
Posted 02 May 2010 - 09:37 AM
Or try a couple of tanks of premium fuel such as BP ultimate or Shell V power as they have cleaning properties added to them.
#4 starfield
starfield
  • New Member
  • 171 posts
Posted 02 May 2010 - 09:44 AM
ok here is the info:
the car is a petrol, 16k miles, 56 reg, zetec with climate and driven mainly urban.
I have read somewhere that redex creates lots of particulates, is that good for the cat?
Will buying premium petrol really help?
#5 hillmangimp
hillmangimp
  • New Member
  • 138 posts
Posted 02 May 2010 - 09:52 AM
Hard to say if premium fuel or additives such as redex will help. If you think the problem may be due to dirt/contamination in the fuel system/injectors it may be worth a go before you take it to a mechanic.
#6 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 20,957 posts
  • Name: James
  • Year: 2007
Posted 02 May 2010 - 11:15 AM
To be fair, the age, and mileage of your vehicle would indicate its less likely to be "wear and tear", items like redex are ok, they do generate particles, but its no worse really than a tank of "unclean" fuel. Excessive use of redex possibly would cause damage over time, however as one off it wont cause any damage. Its always worth a try though, either a 6 bottle of redex, or a 50 diagnostics fee, which may then result in them using the equivelant of a bottle of 6 redex, and labour!
It may well be worth taking your spark plugs out and taking a look for any damage.
Has it always been this way, or has it degraded over time?
#7 starfield
starfield
  • New Member
  • 171 posts
Posted 02 May 2010 - 04:46 PM
i just bought the vehicle a month ago and spark plugs have been changed. It has always been this way since i bought it.
#8 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 20,957 posts
  • Name: James
  • Year: 2007
Posted 02 May 2010 - 05:33 PM
Use the pinned up topic at the top of the forum to check that there are no error codes, if theres nothing there try redex, and other than that you are probably going to have to go to a mechanic.
#9 starfield
starfield
  • New Member
  • 171 posts
Posted 03 May 2010 - 10:18 AM
tried that and no DTC codes
#10 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 20,957 posts
  • Name: James
  • Year: 2007
Posted 03 May 2010 - 05:18 PM
Have you tried the redex?
Not what you're looking for?
