Fcus ST3 problem
#1
Posted 14 August 2008 - 07:57 AM
Dad's ST makes a weird grinding/rubbing noise under the front at the wheels when turned in both directions. The car is standard so no lowering problems or anything.
Does anyone have any ideas what it could be or if this problem has occured on any others?
Dad says it's defo not arches, they clean and in tact.
The noise only happens when moving and turning, not only full lock, any sort of turning angle and it's a tinny sort of noise he says
Dad thinks the brakes have like a tin sort of material thing behind them.
Anyone who knows more about the layout of the brakes on these or what to look for would be appreciated so we don't have to go to ford!
Posted 14 August 2008 - 06:23 PM
I have hurd of a number of things that can cause the same problem you have,
1. is the track rod ends these seem to dry up and can cause i noise
2. is the lower arm ball joints i had mine replaced for the same reasion as your car had and that was when the car was 2 weeks old and had 68miles on the clock
3. i have hurd of many st's having top mount problems they dry up and can cause a creak noise worse when cold.
If i was you just make sure all the bolts every where are tight then start greasing and lubing things up. dont use wd 40, its better to use a silicone spray as its better working in all temps, you may need to undo a few bolts to make sure the spray gets right into it.
Good luck keep us informed Sorry not much help.
#3
Posted 14 August 2008 - 06:28 PM
Hiya
P.s also check the antiroll bar drop links i know the older shape use to suffer from the same problem.
#4
Posted 15 August 2008 - 11:46 AM
I'll let you know if we find out what it is!
Thanks again.
Just thought i'd show you him with his pride and joy - 8500 miles since new in January 2005 and it still looks like it's from the showroom
#5
Posted 15 August 2008 - 08:06 PM
It looks great mate. Good luck for the weekend keep me posted.
Latest Comments
More
