starfield
Auto Lock On Doors
19 posts in this topic
found this on a website:
To deactivate/reactivate the autolock feature using the power door unlock control
You must complete steps 1-7 within 30 seconds or the procedure will have to be repeated. If the procedure needs to be repeated, you must wait 30 seconds.
1. Turn the ignition key to ON.
2. Press the power door unlock control three times.
3. Turn the ignition key from ON to OFF.
4. Press the power door unlock control three times.
5. Turn the ignition back to ON. The horn will chirp.
6. Press the unlock control, then press the lock control.
The horn will chirp once if autolock was deactivated or twice (one short and one long chirp) if autolock was activated.
7. Turn the ignition to OFF. The horn will chirp once to confirm the procedure is complete.
My focus is the mark 2 (56 reg) and apparently does not work on them. For those with the mark one, this might prove useful.
try it and let me know
mk2 procedure is in the hand book
i do not have that, what is the procedure though?
1. Turn on ignition till dash lights come on but don't start engine!
2. Lock the door using the lever on the door handle and then unlock 3 times
3. Turn off ignition
4. Repeat 2 but with ignition OFF
5. Turn on ignition - should hear a beep
6. Lock door again as in 2 BUT ONLY ONCE - final beep should be heard
7. Done!
Doors should now lock at around 5mph. including reverse!!!
not all mk2s have the software inside for it to be done ford removed it from a lot of the cars so that a software update would be needed to switch it on pointless really as you press the handle and do the same thing manually and this only works once per trip
does not work
could it be mine is a later version (56)
I've a Mk2 (2006) Zetec. I've not got this procedure in my handbook.
I asked my local Ford dealer how to do it, and they said that it cannot be done on my car.
Is this what your after
as said the softwre was removed from the focus i dont know when though so that people who wanted this function had to go to ford get the software upgrade which obviously costs money if it doesnt work you dont have the software
it worked for me
No catch. That link seems to discuss how to unlock the drivers door only with a single press of the remote. It doesnt seem to have anything to do with automatically locking the doors once you drive off.
Hi there,
I have the Ford Edge and the garage has told me that for safety reasons I don't have auto lock on my car but I am not sure they are telling the truth. Can anyone help? x
On 5/7/2010 at 8:23 AM, catch said:
it worked for me
In what way did it work? So you managed to enable auto-locking on your car??
Genuinely interested in this...
Don't get your hopes up of a reply, that post is almost 7 years old now.
I enabled the auto lock with the elm config and adaptor with the auto relock for when someone gets out of the car and the car sets off again.
But wow 7 year thread resurrected and still very relevant .
Like some others have found out this doesn't work on all versions, I activated mine using ELMConfig and a lead.
Wow. Oops. lol
I didn't realize the guy above me had resurrected such an old thread, I didn't pay attention to the dates.
Wangarai likes this
Elmconfig and cable worked on 2009 Mk2.5. Also good for our Mondeo Mk4.5. Worth the £15 for the cable just for the auto lock :)
if  this procedure does not work, can it be activated with the elm config or will it need new software from fords?
I think we need to organise a little meet somewhere so that people who want auto lock enabled and people with the software and cable can spend the afternoon configuring there car lol
