Brake Help
21 replies to this topic
#16 stef123
stef123
  • Management
  • 5,864 posts
  • Name: Stefan
  • Ford Model: Mondeo ST TDCI
  • Year: 2006
Posted 07 May 2010 - 08:25 AM
personally i would replace the pipe(s) with cupro nickel brake pipe (kunifer)
a little harder than copper but will withstand alot more pressure and is more resistant to corrosion. only down side is its slightly more expensive.
Have something to contribute?
#17 dezwez
dezwez
    Dezwez
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 5,354 posts
  • Name: Derek
  • Ford Model: ford focus 1.8 zetec mk 2.5
Posted 07 May 2010 - 08:32 PM
just had a quick look on ebay, cheaper than i thought actually.
http://cgi.ebay.co.u...item3a5a5caa59#
you will need 3/16 10*1mm brake pipe nuts also
http://cgi.ebay.co.u...=item3a5a5d32bf
hi steff123 you gave me some help last night i would just like
to ask are these sizes standard on a focus 3/16 10*1mm brake pipe nuts thanks
#18 stef123
stef123
  • Management
  • 5,864 posts
  • Name: Stefan
  • Year: 2006
Posted 07 May 2010 - 08:41 PM
hi dezwez,
yeah 3/16" (4.72mm) O.D pipe is pretty much the standard size on all cars. I cant think why but im sure the thread size is 10x1mm - might have been when i done my brake hoses, again though i think this is quite a standard size for 3/16" pipe.
i have some spare bits of pipe and nuts from when i last touched the brakes so i will go check this for you right now...
#19 dezwez
dezwez
    Dezwez
  • PipPipPipPipPip
  • 5,354 posts
  • Name: Derek
Posted 07 May 2010 - 08:48 PM
hi dezwez,
your a star thank you
#20 stef123
stef123
  • Management
  • 5,864 posts
  • Name: Stefan
  • Year: 2006
Posted 07 May 2010 - 09:15 PM
just thought, i know why i said 10x1mm - when i replaced rear wheel cylinders i was able to screw the bleed nipple (10x1x20mm) into either port meaning the brake pipe nuts are the same thread.
ive just checked for you anyway, definetly 3/16"/4.72mm O.D pipe and 10x1mm thread for the nuts.
#21 dezwez
dezwez
    Dezwez
  • PipPipPipPipPip
  • 5,354 posts
  • Name: Derek
Posted 07 May 2010 - 09:17 PM
cool thank you so much.
#22 stef123
stef123
  • Management
  • 5,864 posts
  • Name: Stefan
  • Year: 2006
Posted 08 May 2010 - 12:30 AM
i dont want to start confusing things more but you will need to make sure you get a tool that is capable of making DIN/ISO/bubble flares (call it what you will). not sure if the cheaper ones will do this or not.
cheers
stef
Not what you're looking for?
