Bhp
david raptor
 Share
i have you brought a ford focus 1.6 2007 zetec climate how could i find out which bhp
and i have a miss fire only when doing about 60 mph in 5 gear but not all the time
Link to comment
its 96bhp for all 1.6 zetecs the misfire could be a plug or lead best to change them first and if it still continues then possibly it may need the coil pack replaced check the dash using the trick on the main page and see if any codes are stored
Link to comment
The 1.6 MKII came in two variants. The 96bhp and the 115bhp (115ps). The latter is the Ti-VCT engine, the former the regular Zetec/Duratec (whatever they decided it is).
Link to comment
[/quotif it was built before 31st december 2007 its a 96bhp if it was built after that its a 115bhp put youre reg in here and youll find out all you need to know http://www.etis.ford.com/vehicleRegSelector.do;jsessionid=1F98D4FA6305ABB6195777BD16320E99.dulv0676
Link to comment
i have a look the car is 115 bhp it dont go very well she on a 07 but the car as not done any work as she only done 14000 i did that test but it said all clean
Link to comment
to be honest it can cost 70 quid but a diagnostic can be worth it for example you could change plugs leads and coil pack and still hqav ethe same issue then you start replacing sensors etc you could spend a few hundred trying to fix it fords diagnostic machine will find a code if ones there if not they can look at the live data
Link to comment
just to let you guys kwon it is the coil pack i took the car back to were i bought it from should have the car back to morr
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
