Stoney871 Posted October 27, 2012 Share Posted October 27, 2012 Usually the only bulbs that have offset tabs are double filament bulbs like brake lights so as to avoid the wrong elements being lit. Quote Link to comment Share on other sites More sharing options...
AJ_sXe Posted October 28, 2012 Share Posted October 28, 2012 Usually the only bulbs that have offset tabs are double filament bulbs like brake lights so as to avoid the wrong elements being lit. Cool beanos....now I know what I am doing Monday before work starts! Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted October 28, 2012 Share Posted October 28, 2012 Good drills Sir. :D Quote Link to comment Share on other sites More sharing options...
tazman927 Posted February 2, 2013 Share Posted February 2, 2013 What sort of guide wouldn't help you put the headlight back in? Honestly people! Grab your headlight lets go ... ------------------------------------------- Replacing the headlight back into the mounting: Meanwhile at your car lol. FIRST! Plug the connector back in and ensure the lights are working! Do not do anything else untill you have otherwise you'll be scrolling all the way back to the top of this guide...bad times. All working? Are you now blinded by the pure brilliance ... Odds are no, its still daylight ha ha Anyway ... So remember the little plastic tabs on the headlight Those will play a key part in making this part SO So Simple. Insert the bottom (narrow) part of your headlight into the mounting first. After all it was this part that made it hard removing it in the first place. With the headlight in place at the bottom (ensure the plates for the bolt and rivet are UNDER the grill and not ontop) tilt the headlight and work on getting those plastic tabs into under the bodywork During this step, odds are you will head the plastic clip at the bottom of the headlight clip into place and the headlight will fit snug. If this hasn't happened, have a good place around. Don't worry, there is only One way for the headlight to sit correctly and multiple ways to get it there. Insert the bottom part of the rivet Followed by the top part Replace the other two bolts and washer, reconnect the connector at the back of the headlight. Close the bonnet and marvel the fact your indicator isn't orange Now... we wait for the darkness to fall Result to follow Hope this has helped or given confidence to those wanting to give it a go. Rogue Shadow Quote Link to comment Share on other sites More sharing options...
jd_james Posted March 13, 2013 Share Posted March 13, 2013 Are there any images from you referring to what these bulbs you bought look like? Interested in buying them for my new motor but want to see the results. Philips Blue Vision Ultra H7 (Twin Pack) Philips Blue Vision Ultra W5W 501 (Twin Pack) PHILIPS SILVERVISION PY21W OFFSET PIN INDICATOR BULB Quote Link to comment Share on other sites More sharing options...
Gerhardva Posted July 20, 2013 Share Posted July 20, 2013 Just did my indicator bulbs on the MK7 ST, no need to even remove the light. It has DRL's, so no Side lights. Quote Link to comment Share on other sites More sharing options...
Thom Posted July 25, 2013 Share Posted July 25, 2013 Without this guide I'd never have managed to get my fog light replaced! Many thanks. Quote Link to comment Share on other sites More sharing options...
geetee Posted July 30, 2013 Share Posted July 30, 2013 Hi I'm a total newbie I want to replace my footwell lights with the ones posted in this thred from eBay Having trouble getting the original bulbs out Can I get a lil help Quote Link to comment Share on other sites More sharing options...
iNath Posted July 30, 2013 Share Posted July 30, 2013 Hi I'm a total newbie I want to replace my footwell lights with the ones posted in this thred from ebay Having trouble getting the original bulbs out Can I get a lil help You literally just pull. Quote Link to comment Share on other sites More sharing options...
Joe_mk7zs Posted September 10, 2013 Share Posted September 10, 2013 Did a photo of the fitted blue vision bulbs ever get uploaded? Quote Link to comment Share on other sites More sharing options...
Anyatan00 Posted November 9, 2013 Share Posted November 9, 2013 Guys. Need help here before i ruin this.. Seems like the headlight assembly of the 2013 fiesta is different along with its bulb mounts. I have posted pictures of the headlight itself, the high/DRL and sidelight assembly.. I am planning to change both the high/DRL and sidelight bulbs but i dont want to force it. Anyone have experience removing these? THanks. Quote Link to comment Share on other sites More sharing options...
iNath Posted November 9, 2013 Share Posted November 9, 2013 Sidelights just pull out, only changed that and indicators on MK7.5 so can't comment on other bulbs. Quote Link to comment Share on other sites More sharing options...
Anyatan00 Posted November 10, 2013 Share Posted November 10, 2013 Thanks. Done. Note: Dont use your fingers(there are sharp edges in there - ended up cutting myself trying pull them out) USE pliers to pull them out! Quote Link to comment Share on other sites More sharing options...
iNath Posted November 10, 2013 Share Posted November 10, 2013 I used pliers and snapped one =/ Quote Link to comment Share on other sites More sharing options...
Mayday Posted November 14, 2013 Share Posted November 14, 2013 This was a great help with replacing the two dipped beam lamps on my Fiesta - The job was very straightforward, even the clips all came apart without problem. Excellent guide Quote Link to comment Share on other sites More sharing options...
M4RC Posted December 2, 2013 Share Posted December 2, 2013 Hi, I have a fiesta mk7 zetec s. I'm looking to change my main beam, dipped and fog lights. Can someone give me a link to some? I'm just looking for a more bright white light, preferably with a hint of blue if possible? Any help is appreciated. Thanks Quote Link to comment Share on other sites More sharing options...
E.HarrisSkye Posted January 13, 2014 Share Posted January 13, 2014 Are the H7 Dipped Beam a two prong fitting? Quote Link to comment Share on other sites More sharing options...
GlynnZS Posted February 13, 2014 Share Posted February 13, 2014 Just fitted some CREE LED Bulbs in my fog lights and thought I'd letpeople know a very easy way to change fog light bulbs on a mk7.5...Turnyour front wheels full lock to one side and unscrew two screws on thelining of the arch just behind where the fog light is, the arch liningthen moves away really easily and you can get to the rear of the foglight and also see what you are doing. The bulb holder/plug then justtwists 90 degrees and comes out allowing you to change the bulbs. Mucheasier than taking the headlight off and doing it through the bonnet,as the passenger side fog light is blocked by the windscreen washreservoir. Quote Link to comment Share on other sites More sharing options...
SandyCat Posted February 16, 2014 Share Posted February 16, 2014 Ethan yes they are 2 pronged and stiff to get out. I have just changed mine and I had to get a screwdriver between the plates to prise it out! As for the headlight units I couldn't have done it without this guide although I was about to give up when the first one just wouldn't budge until I found that after releasing the 2 clear tabs if you twist the bottom of the light that runs along the bumper out towards you and pull up at the same time it frees quite easily and the other one then came out without all the swearing. Someone mentioned that you can changed the dipped without removing the headlights by taking off the dustcap and I thought that when I looked but I still wanted to have a go. At the end of the day the design is a disgrace and these bulbs should just slide in from above cartridge style. And to think some countries require this to be a roadside job with spare bulbs carried in the car! Also when I put my lights back in they all screwed in OK but I noticed a large gap between the light and the bumper so obviously they were not sat right in the white clip so I undid the screws again and did lots of pushing and shoving and they went OK. So make sure you check the alignment of the unit along the bumper by crouching down although a small gap towards the front is normal due to the weight of the bumper pulling it down. Quote Link to comment Share on other sites More sharing options...
rueboy66 Posted July 13, 2014 Share Posted July 13, 2014 thanks for the guide it really helped me yesterday. Quote Link to comment Share on other sites More sharing options...
Maxxxykins Posted July 19, 2014 Share Posted July 19, 2014 Thanks for this guide, the front indicators on the mk7 are a right pain in the... Well they were on mine anyway. Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
7parky Posted August 8, 2014 Share Posted August 8, 2014 Hi Changed mine today H7 Followed the guide ,many thanks Very easy to my surprise only took 20 mins to do both sides Quote Link to comment Share on other sites More sharing options...
craigdavid1987 Posted September 23, 2014 Share Posted September 23, 2014 Thanks for the guide it was very helpful! Has anyone noticed when they replace the headlight it seems to not sit back very snug? Or is it just me? Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
bensambrook Posted October 9, 2014 Share Posted October 9, 2014 Had a look at this earlier, how do you get the plastic rivet off holding the headlight to the grille? Mk7.5 Zetec S? Quote Link to comment Share on other sites More sharing options...
7parky Posted October 9, 2014 Share Posted October 9, 2014 The centre of the plastic rivet lifts up about quarter of a inch and then you can pull the complete plastic plug out it is very easy Quote Link to comment Share on other sites More sharing options...
