Ford Fiesta '99 switches off while driving
#1
Posted 19 August 2008 - 08:34 AM
am newbie here,hope you could be tolerent with me.
I have Ford Fiesta '99,1.3 engine,after the engine warms up and while driving,when I come across junctions,I slow down I see the engine switches off !!!,this happens around 4 to 5 times a day,also I notice that it has rough idling,some told me it is the idle control,others told me it is the air mass.
What do you think?
Thanks in advance
#2
Posted 19 August 2008 - 12:45 PM
#3
Posted 19 August 2008 - 09:21 PM
Is it an easy DIY? or I should visit a workshop?ita a comman problem cleaning the idle controlle valve should cure it
#4
Posted 19 August 2008 - 09:25 PM
#5
Posted 19 August 2008 - 09:46 PM
How can I reach the idle control valve?
its not a mechanics job really, basically if u look at ur engine its just above it, its hard to explain what it looks like, but mine went on mine, what happened with mine was that when u rev it up and let it drop it kept dropping n just stopped altogether. Basically thats what u need below, its easy enough to see, once you look at the picture then at your engine, you'll spot it just above it.
http://cgi.ebay.co.u...id=p3286.c0.m14
#6
Posted 19 August 2008 - 09:54 PM
It could be a cylindrical oblect with a plug on it, bolted on the injector body, clean it out wit some carb cleaner, NO sharp objects.
#7
Posted 19 August 2008 - 10:34 PM
its a diy job as far as i can remember as diferent models have different valves
It could be a cylindrical oblect with a plug on it, under the air filter bolted on the injector body, clean it out wit some carb cleaner, NO sharp objects.
its not, mines same engine, n i got the link above to show what it looks like
#8
Posted 20 August 2008 - 09:16 AM
very easy DIY
