hi my 99 focus idles ok in the daytime butb when i am driving at night and i have my lights on the car idles slightly rougher but is ok with just the side lights on
is tiis because there is more load on the engine with the lights fuly on
idling
Started by fontaine, Aug 20 2008 01:49 PM
3 replies to this topic
#1
Posted 20 August 2008 - 01:49 PM
#2
Posted 21 August 2008 - 08:44 AM
if you disconnected the battery for any reason it could have reset the computer's idling, just disconnect the battery put the parking brake on reconnect the battery and start the car, let it run for a minute, then turn on a/c lights radio and let it sit another minute, then drive for about 30 mins so the car can relearn its idle!!(make sure you know your radio code)if this does not cure the problem check your alternator voltage to make sure its ok
#3
Posted 02 September 2008 - 03:51 AM
I also got this annoying problem few months ago. During start up, my engine revs up for about 2500 rpm and let it stay for about 3 seconds then goes down to 1800 and stays up for about 1-2 seconds and then the idling comes at 900 rpm. Damn!
__________________________________________________
Powered by Honda Parts
#4
Posted 02 September 2008 - 04:29 AM
Thanks!
