Window
9 replies to this topic
#1 markev
markev
    Newbie
  • Pip
  • 4 posts
  • Ford Model: galaxy
Posted 26 May 2010 - 09:42 PM
hi i have a galaxy (n reg) the problem is my passenger window my 2 year old son was sending it up and down up and down,now when i press it to go up it does but comes half way back down on its own...any ideas thanks
#2 calmcdermott
calmcdermott
    Area Rep: Northeast
  • 548 posts
  • Name: Callum
  • Ford Model: Ford Fiesta ST500
Posted 26 May 2010 - 09:45 PM
Push the down button and keep hold of it and i think the window will reset and go all the way down, if not do vise versa, just a guess.....
#3 markev
markev
    Newbie
  • Pip
  • 4 posts
Posted 26 May 2010 - 09:50 PM
thanks...it will go down but it just will not stay up as soon as you push up and it gets to the top it just comes back down on its own to halfway
#4 calmcdermott
calmcdermott
    Area Rep: Northeast
  • 548 posts
  • Name: Callum
Posted 26 May 2010 - 09:53 PM
Im not too sure then matey, did you try what I said, if you understood :lol:, im not good at explaining lol!
#5 markev
markev
    Newbie
  • Pip
  • 4 posts
Posted 26 May 2010 - 09:57 PM
yes thanks...it just wont stay up,off the passenger switch our the drivers
#6 calmcdermott
calmcdermott
    Area Rep: Northeast
  • 548 posts
  • Name: Callum
Posted 26 May 2010 - 10:00 PM
Have you tried it with the driver's side?
#7 markev
markev
    Newbie
  • Pip
  • 4 posts
Posted 26 May 2010 - 10:08 PM
just tried it but no luck,but just noticed it stays up when i lock it with key but comes back down when open
#8 mintalkin
mintalkin
  • PipPipPipPipPip
  • 3,321 posts
  • Name: mintalkin
  • Ford Model: mondeo tdci 130
  • Year: 2006
Posted 27 May 2010 - 03:28 PM
it sounds like the memory has been altered, press the button to fully close the window, release for one second and then press up again for two seconds, this should reset the memory for the window, repeat for down position if required.
#9 I will fix it!
I will fix it!
    Member
  • PipPip
  • 16 posts
  • Ford Model: Focus
Posted 29 May 2010 - 10:52 AM
your problem is a simple fix! all you need is your d/s/f top window noulding lubricated with silicone spray and the window adjusted! Try lubrication first that might just do it. It's not your door module/window motor trust me.
#10 artscot79
artscot79
  • PipPipPipPipPip
  • 5,333 posts
  • Name: arthur
  • Year: 2006
Posted 31 May 2010 - 09:13 PM
have a look up in the window nnel and see if youre son stuck summat up there if the window senses that there is resistance ie fingers stuck in the window it will automatically drop down half way again
