Chris Ecc Posted May 29, 2010 Share Posted May 29, 2010 Since i was last here made a few changes to the fez, I've fitted a K&N Panel Filter and High Flow Samco Air Pipe which are the same as the ones used in the Mountune Performance upgrade. They have given a small increase in power at lower revs which is all I was expecting really :) I've also took the plunge and used the guide on here to retrofit the ambient lighting, didn't take that long and is actually very simple to do! High Flow Air Pipe K&N Panel Filter Ambient Lighting Relatively Clean Quote Link to comment Share on other sites More sharing options...
eagle_gr Posted May 29, 2010 Share Posted May 29, 2010 Is there a substantial difference between the original air pipe and the "high airflow" one? :o Quote Link to comment Share on other sites More sharing options...
C-Max Boy 1983 Posted May 29, 2010 Share Posted May 29, 2010 Nice wee mods you have done there and nice looking Fiesta. Davy Quote Link to comment Share on other sites More sharing options...
Chris Ecc Posted May 29, 2010 Author Share Posted May 29, 2010 cheers c-max boy :) ermm well I fitted them both at the same time so not sure, but they use the same gear on mountune pack so gotta do summit lol, the stock air-pipe is !Removed! tbf because it can extended so its got like the corrugated bit in the middle thats rubbish for airflow Quote Link to comment Share on other sites More sharing options...
