Idle Air Control Valve
5 replies to this topic
#1 frannerc73
frannerc73
    Newbie
  • New Member
  • Pip
  • 3 posts
  • Ford Model: focus
Posted 06 June 2010 - 11:56 AM
how do you change the idle air control valve in a 2000 w reg focus?????
Have something to contribute?
#2 stef123
stef123
  • Management
  • 5,808 posts
  • Name: Stefan
  • Ford Model: Mondeo ST TDCI
  • Year: 2006
Posted 06 June 2010 - 03:53 PM
hello and welcome,
what size of engine is it?
#3 frannerc73
frannerc73
    Newbie
  • New Member
  • Pip
  • 3 posts
  • Ford Model: focus
Posted 06 June 2010 - 04:29 PM
hello and welcome,
1799
#4 artscot79
artscot79
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 7,941 posts
  • Name: arthur
  • Year: 2006
Posted 06 June 2010 - 08:20 PM
1799
you can do it from above or below i found above easier to make room remove the airbox easiest way without touching the maf is to loosen the clamp on the airbox side remove the 4 top screws so the upper part of the airbox comes off and put to the side now just pull up on the bottom part and the airbox is out now you can get into the icv disconnect the wiring plug and simply undo the two bolts holding it in place i think they are 15mm cant remember fitting is just the reverse simple job to do
#5 stef123
stef123
  • Management
  • 5,808 posts
  • Name: Stefan
  • Year: 2006
Posted 06 June 2010 - 08:40 PM
if its similar to the 1.6 engine the bolts are 8mm hex heads i think
#6 frannerc73
frannerc73
    Newbie
  • New Member
  • Pip
  • 3 posts
  • Ford Model: focus
Posted 08 June 2010 - 07:18 AM
thanks m8
Not what you're looking for?
