Cooling Fan
8 replies to this topic
#1 artscot79
artscot79
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 7,892 posts
  • Name: arthur
  • Year: 2006
Posted 09 June 2010 - 07:17 PM
does the cooling fan on the focus run even with the ignition off or should it go off when the ignition is switched off also
Have something to contribute?
#2 dezwez
dezwez
    Dezwez
  • PipPipPipPipPip
  • 5,075 posts
  • Name: Derek
  • Ford Model: ford focus 1.8 zetec mk 2.5
Posted 11 June 2010 - 08:13 PM
mine go;s off when i swicth off 1.8 petrol lx 52 reg
#3 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 20,664 posts
  • Name: James
  • Year: 2007
Posted 11 June 2010 - 09:28 PM
IT can run afterwards if the engine is too warm, for a few minutes, just bring a bit of cool and calm to the engine. Nothing to worry about...
#4 artscot79
artscot79
  • PipPipPipPipPip
  • 7,892 posts
  • Name: arthur
  • Year: 2006
Posted 11 June 2010 - 10:44 PM
just wonderd asi was checking the operation of it with the dash temp readout on and the fan cut in as it should so i switched the car off and the fan also went off as well so wasnt sure my old cars had fans that ran with the engine viscous coupling fans so electric ecu controlled fans are new to me
#5 ford focus edge
ford focus edge
  • New Member
  • 775 posts
  • Name: Mike
  • Ford Model: Focus 2.5T ST-2
Posted 12 June 2010 - 08:47 AM
My fan rarley comes on even on scorching hot days and after serious abuse :huh:
Mike
#6 artscot79
artscot79
  • PipPipPipPipPip
  • 7,892 posts
  • Name: arthur
  • Year: 2006
Posted 12 June 2010 - 02:06 PM
My fan rarley comes on even on scorching hot days and after serious abuse Posted Image
Mike
take it f a drve with the dash trick on then park it in the drive running and allow it to idle watch the dash temp it should cut in before 100 degrees 98 i think and then cut out around 94 if it dioesnt then lift the lid on the fuses in the bonnet theres 4 small rectangular relays youll see the end ones for the fan replace this and likely it will work they sometimes stick open or shut open is fan running constant closed is fan not running at all mine rarely comes on but once a month i check it nad make sure its working as it should
#7 ford focus edge
ford focus edge
  • New Member
  • 775 posts
  • Name: Mike
Posted 12 June 2010 - 02:55 PM
Its not cooking itself it just dosent seem to come on unless its near silent, say for example if i absoutly NAIL it to college and back then do the same in the ST220, the front of the mondeo is glowing warm with the fan on, mines warm but nothing to bad at all with no extra noise.
I think il leave it well alone its just been serviced and mot's and passed with flying colours dont want to go buggering things up again lol.
Mike
#8 Wibbly
Wibbly
  • New Member
  • 40 posts
  • Ford Model: Focus Zetec 1.6 tdci
Posted 13 June 2010 - 08:15 PM
Mine does it even in cold (freezing) weather sometimes. I checked with Ford. Normal. Apparently it designed to do it under certain conditions as a technique for stopping it freezing up...
#9 artscot79
artscot79
  • PipPipPipPipPip
  • 7,892 posts
  • Name: arthur
  • Year: 2006
Posted 14 June 2010 - 03:28 PM
think it was just the act it switched off when the ignition went off most other cars they either stay on or switch back on again saying that when i restarted the car in diagnostics and checked the temp it was 94 so the fan would have cut off anyway
Not what you're looking for?
