Run Back
3 replies to this topic
#1 andypandyholmes
andypandyholmes
    Newbie
  • New Member
  • Pip
  • 2 posts
  • Ford Model: Escort van
Posted 12 June 2010 - 10:39 PM
Hi all. I am new on here. I recently bought a 1.8turbo diesel escort van. It seems to have a starting problem cold or hot. I have checked the heater plugs and they are fine. I have changed the fuel cellanoid. I think diesel is running back from the pump because if I hand prime the pump, the van starts first time. I have changed the lift pump, and the problem is still there. Does anyone have any ideas on what to do next?
Have something to contribute?
#2 mintalkin
mintalkin
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 3,560 posts
  • Name: mintalkin
  • Ford Model: mondeo tdci 130
  • Year: 2006
Posted 13 June 2010 - 01:43 PM
it could be the non return valve in the filter body playing up,or an igress of air allowing the fuel to seap back.
#3 andypandyholmes
andypandyholmes
    Newbie
  • New Member
  • Pip
  • 2 posts
Posted 13 June 2010 - 06:54 PM
Thanks... I am thinking of putting a non return valve between the fuel pump and the primer as an easy way to solve the problem. Do you think it would work?
#4 lublin
lublin
  • Budding Enthusiast
  • 101 posts
  • Ford Model: Escort Estate 1.6 16v . Built 14/11/95.
Posted 13 June 2010 - 09:14 PM
Are there any signs of weeping from any of the joins around the injectors? Or any signs of spannering on the nuts on the injectors as someone may have removed 1 for whatever reason and either not used a new seal (copper washer?) or not tightened the nuts enough BUT don't strip anything.
"Thanks... I am thinking of putting a non return valve between the fuel pump and the primer as an easy way to solve the problem. Do you think it would work?"
I would get a secondhand filter body 1st because the original setup will be best. Also if the valve is too small it could cause a restriction and so too much pressure at the fuel pump, I have seen an engine fill with diesel because of a crushed fuel pipe which caused the pressure to build up(don't know if Fords use the same type of pump as it was on a John Deere tractor)
Not what you're looking for?
