stevei
Ticking Noise
4 posts in this topic
After a while driving i have noticed a slight "ticking noise" which gets worse over time. If i slightly depress the brake pedal is disappears, then comes back after a while.
Abyone any ideas??
Abyone any ideas??
will be helpful if more details are availble: mileage, manual / auto, diesel / petrol, etc
1.6 Petrol Ghia
Ghia
Auto
25k miles
Hope that this gives you a clue
below is a quote from the honest john website:
On the 1.6 auto, a sound like a relay clicking on and off repeatedly at idle or light throttle settings (at first thought to be connected with the rough idle) is explained as the Bowden cable connecting the gear shift to the gear box has an alloy junction box situated inside the car under the interior fan unit to provide free play. Re-routing the cable in the engine bay so it is no longer under tension gets rid of the noise.
the url is:
http://www.honestjohn.co.uk/carbycar/ford/focus-ii-2004?section=bad
hope this helps
