Sign in to follow this
tictac
Mot Failure
Hi everyone, i just got my 1999 T Reg 1.6 Zetec back from MOT Testing centre and it has failed on a couple of things. What Im concerned about is the advisories that came with it
1. Susension Joint Offside Lower Dust Cover Split/Missing
2. Steering rack side rod joints worn slightly. Lowered suspension fitted alround. Sill covers fitted. Front subframe has
surface corrosion.
How is lowered suspension warrant an advisory notice?
Anyone got any ideas what exactly all that means and how I can put it right?
Thanks in advance. Any comments/suggestions and or ideas all gratefully received.
Regards
surface corrosion.
Regards
they always say sill covers fitted the fords meant to have them so ignore that part the steering rack joints are inexpensive split cv joint boot by the sound of it yet agauin inexpensive and nowt to worry about front subframe ide get the car up on ramps use a wire brush on it and then spray it with dinitrol or waxoyl underseal.
I just ordered sum dinitrol. Thanx for advice ARTSCOT79.
