Fuel Cap
2 replies to this topic
#1 gafflad2010
gafflad2010
    Newbie
  • New Member
  • Pip
  • 2 posts
  • Ford Model: 1996 mondeo 1.8 lx
Posted 20 June 2010 - 02:11 PM
:) hi guys im new on ere and never used a forum before well hear we go i own a 1996 1.8 16v LX mondeo and i have a problem with the fuel cap inside the driver door there is a lever that opens the boot if pulled up and pushed down it is meant to open the fuel cap but it does not i have to spend ages before it will work what could this be and is it an easy fix as i have been informed that it is an M.O.T failure if not working any help would be most greatfull as M.O.T is due next month
Have something to contribute?
#2 mintalkin
mintalkin
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 3,551 posts
  • Name: mintalkin
  • Ford Model: mondeo tdci 130
  • Year: 2006
Posted 20 June 2010 - 02:37 PM
it could be just stuck,get a mate to help,hold the release lever up, then carefully ease the flap open.Once it is opened ,then lube the plastic pivot hinge and also the spring loaded release plunger.you can also locate the release cable from inside the boot behind the trim.
#3 gafflad2010
gafflad2010
    Newbie
  • New Member
  • Pip
  • 2 posts
Posted 21 June 2010 - 12:18 AM
ok thanks i will try that tommorrow :)
Not what you're looking for?
