jimjamer Posted August 31, 2008 Share Posted August 31, 2008 I have just bought a 03 streetka it has 41k on it and i was wondering 1. when the belt will need changing ? 2. how much will it be ? i'm getting it seviced any way as its a car for my wife and I want to make sure its safe. 3. what is the best oil to use in car ? 4. where is the best place to buy parts for car ? 5. what is the best thing to treat roof with ? thanks for any help and advise you can give Quote Link to comment Share on other sites More sharing options...
mintalkin Posted September 7, 2008 Share Posted September 7, 2008 to answer a few of your questions 1 if i remember right the streetka has the 1.6 endura 8v engine which is chain driven 2 any good quality 5-30 oil will be ok 3 there are plenty of online parts providers for ford like fordparts uk 4 its best to do the roof with a two part system,one to clean and one to protect,companies like autoglym sell this hope this helps Quote Link to comment Share on other sites More sharing options...
Rikos Posted September 8, 2008 Share Posted September 8, 2008 Hi and welcome to the club If you look in the service book it should give you a mileage and year for the cambelt/chain change. If mintalkin is right about the chain driven engine then i know this normally last longer than a belt but i believe it is more expensive. oil as mintalkin says any good 5-30 will do. What kind of parts are you after? There are quite alot of soft top cleaners out there for you to choose from but having never owned one i cant say which is the best i'm afraid. Quote Link to comment Share on other sites More sharing options...
steve2507 Posted October 14, 2017 Share Posted October 14, 2017 Hi Iknow this post goes back to 2008 ,it is the same question only i have a streetka 1.6 16v. I have been looking for cambelt and tensioners, i hane explored on google but no info relating to how many tensioners i need.. i normally buy Gates cambelts and waterpump in same kit, but not available on streetka.. Thanks Steve Quote Link to comment Share on other sites More sharing options...
iantt Posted October 14, 2017 Share Posted October 14, 2017 no such engine as a 1.6 16v in a ka street ka has 1.6 8valve duratec rocam engine and that is chain drive. Quote Link to comment Share on other sites More sharing options...
andybadcats Posted October 22, 2017 Share Posted October 22, 2017 On 14/10/2017 at 8:55 AM, iantt said: no such engine as a 1.6 16v in a ka street ka has 1.6 8valve duratec rocam engine and that is chain drive. The Sport Ka is a 1.6 16 valve and that is classed as a Ka car. Re the belt. It's called the Auxiliary Belt and the tensioner is a spring, operated by a bolt which when turned releases the belt and allows reacememt plus the water pump can then be replaced too. I got the belt and water pump from Eurocarparts both about £35 for top end generic version. Quote Link to comment Share on other sites More sharing options...
