Front wipers banging at the top
Started by mahall1988, Sep 05 2008 02:04 PM
7 replies to this topic
#1
Posted 05 September 2008 - 02:04 PM
When I put my front wipers on when they reach the standing straight up position they bang after a couple of months of trying to figure out what it is I can see that the metal bit that sticks out of the blade hits the windscreen.
I took it into the ford garage and they told me that cheap wipers don’t fit properly on my car so they fitted new ones, which cost me. They worked for a few months but the problem has just come back again.
I'm now completely stuck as to why it does this and would appreciate any help on fixing this.
I have a 54 reg fiesta LX model
Thanks in advance
Thanks in advance
#2
Posted 05 September 2008 - 02:26 PM
What metal bit? Any chance of some pictures so we can see what the problem is.
#3
Posted 06 September 2008 - 02:04 PM
sounds like the arms require adjustment or the wipers are too long
#4
Posted 07 September 2008 - 06:30 PM
I cannot provide a photo because I have no camera but it is the metal lip this is just below the blade.
Ford fitted the wipers and they weren’t banging for a couple of months and no one has touched them since, but if you could tell me how to do it id appreciate it as well.
#5
Posted 08 September 2008 - 07:53 AM
are they hitting the glass or the rubber surround? and where on the stroke of the blades
#6
Posted 08 September 2008 - 05:05 PM
He means the metal support which is situated on both sides of the rubber blade, it's "sunk" into the blade in a slot on either side and the actual wiper arm normally grips the metal support in about 6 positions along the wiper blade length. Normally on the cheaper blades this works it's way loose, sometimes there are cut outs in this metal support which should sit on moulded areas on the blade!
#7
Posted 08 September 2008 - 05:08 PM
duplicated post so deleted it
#8
Posted 08 September 2008 - 05:31 PM
might be too much arm pressure towards the screen over stressing the blades causing the problem if not you could try bosch one piece aero blades
