ST170 brakes
11 replies to this topic
#1 Gwyn
Gwyn
    Member
  • PipPip
  • 10 posts
  • Ford Model: Focus ST170
Posted 07 September 2008 - 07:15 AM
Hi there, new to the forum but not to Fords :rolleyes: :rolleyes: :rolleyes:
Problem with the brakes, ford focus ST170, coming to a stop from around 20-15mph to 0, you can feel the brake pedal pumping (not fast, around once a second). Is this an abs sensor fault or warped front discs, the car has just covered 27,000.
Any suggestions or experiences with this type of problem
Gwyn :unsure: :unsure: :unsure:
#2 mintalkin
mintalkin
  • PipPipPipPipPip
  • 3,321 posts
  • Name: mintalkin
  • Ford Model: mondeo tdci 130
  • Year: 2006
Posted 07 September 2008 - 01:58 PM
90% sure it will be a warped disc
#3 Gwyn
Gwyn
    Member
  • PipPip
  • 10 posts
Posted 07 September 2008 - 07:16 PM
thanks for that info mintaklin
I'll source some discs this week, my previous car did 127,000 (9" solid discs) miles with the same discs, so much for 300mm vented discs brakes :rolleyes: :rolleyes: :rolleyes:
#4 mintalkin
mintalkin
  • PipPipPipPipPip
  • 3,321 posts
  • Name: mintalkin
  • Year: 2006
Posted 08 September 2008 - 08:03 AM
see if you can get hold of a dial gauge to check the run out of the discs before buying new just in case its something else
#5 Gwyn
Gwyn
    Member
  • PipPip
  • 10 posts
Posted 08 September 2008 - 11:29 AM
Hi mintalkin
What's the max +/- in mm/thou (run out) you would expect to get on a dial guage reading before rejecting the discs. :unsure: :unsure: :unsure:
kind regards
Gwyn
#6 mintalkin
mintalkin
  • PipPipPipPipPip
  • 3,321 posts
  • Name: mintalkin
  • Year: 2006
Posted 08 September 2008 - 12:24 PM
anything above 0.1mm (0.004”).would most likely cause pulsating
#7 Gwyn
Gwyn
    Member
  • PipPip
  • 10 posts
Posted 08 September 2008 - 02:13 PM
Thanks again mintalkin.
Will borrow a DTI from work midweek, will post the result hopefully by the weekend.
regards
Gwyn :rolleyes: :rolleyes:
#8 Gwyn
Gwyn
    Member
  • PipPip
  • 10 posts
Posted 13 September 2008 - 11:24 AM
regards
DTI checks on each corner
Front off-side 0.03mm
Front near-side 0.03mm
Rear off-side 0.02mm
Rear near side 0.45mm :angry: :angry: :angry:
It was obvious when I jacked up the car (Rear-near side), that this was the culprud, the wheel was binding when Hand turned at one particular point, Further investigation showed a deviation of .45mm at this point for approx 12cm. Have ordered some discs today and hopefully put them on Tuesday evening. The brakes on this corner must have been running hot, hence affecting the performance & MPG.
Thanks again
Mintalkin
regards
G Jones
#9 mintalkin
mintalkin
  • PipPipPipPipPip
  • 3,321 posts
  • Name: mintalkin
  • Year: 2006
Posted 13 September 2008 - 02:15 PM
no problem glad you found the culprit
#10 Gwyn
Gwyn
    Member
  • PipPip
  • 10 posts
Posted 16 September 2008 - 06:10 PM
:rolleyes:
I fitted new rear discs and pads this afternoon, it solved the problem. Used Ford origional parts, worst job was to push back the piston in the caliper. Your suppose to use a special ford tool, I got away with a 4" G clamp, made for the job, allthough it required a lot of effort to push the piston back.
Happy motoring :rolleyes: :rolleyes:
ps Thank god for forum's, saves a fortune in the end and a real satisfaction of doing and solving the problem yourself.
Gwyn
#11 Rikos
Rikos
  • 857 posts
  • Ford Model: Fiesta 1.4 LX
Posted 17 September 2008 - 08:52 AM
Really glad that you managed to get this sorted
And good to see the forum could help ... thats what we're here for!
#12 vinnyvangough
vinnyvangough
  • Super Mod
  • 2,225 posts
  • Name: Steve
  • Ford Model: Ford Escort RS2000 Mk6 & Mk2 Escort
  • Year: 1996
Posted 17 September 2008 - 11:11 AM
Result for FOC
