hi there new to the site, very good from what ive seen i have a ford focus 1.4 16v y reg 2001 and the engine managment light has come on i have read the trouble code on my mates scanner, p0420 cat bank 1 below threshold? will this need a new lambda sensor in the exhaust or a wiring fault? is this 2 sensors on this car 1 before cat and one after? what do you ford guys recon out there? any help much appriciated cheers!!!!!!!!!!!!!!!!!!!!!!
focus engine managment trouble
Started by wadi, Sep 07 2008 11:06 AM
1 reply to this topic
#1
Posted 07 September 2008 - 11:06 AM
#2
Posted 07 September 2008 - 02:12 PM
it might just be the sensor before the cat thats playing up, with all the wet weather we have had first check that the seal is tight and not letting in any water witch would throw the code it could also be any of the following
Damaged HO2S
Malfunctioning ECT
High fuel pressure
Damaged exhaust manifold
Damaged catalytic converter
Oil contamination
Cylinder misfiring
Downstream HO2S wires improperly connected
Damaged exhaust system pipe
Damaged muffler/tailpipe assembly
Retarded spark timing ng
Damaged HO2S
Malfunctioning ECT
High fuel pressure
Oil contamination
Cylinder misfiring
Latest Comments
More
