Hi Revs Loss Of Power
19 replies to this topic
#1 andy_1984
andy_1984
  • New Member
  • 131 posts
  • Ford Model: Focus LX Estate
Posted 21 July 2010 - 06:16 PM
started getting loss of acceleration today. the revs build up but its just so sluggish getting it up to speed and i can feel vibrations like going over a sutle little rumble strip.
revs get to 3k just as im getting to 20mph!
from what i gather my clutch is on its way out, but is it possible it could be anything else ?
Have something to contribute?
#2 mintalkin
mintalkin
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 3,543 posts
  • Name: mintalkin
  • Ford Model: mondeo tdci 130
  • Year: 2006
Posted 21 July 2010 - 07:05 PM
i would say the clutch is worn.
#3 andy_1984
andy_1984
  • New Member
  • 131 posts
Posted 21 July 2010 - 10:16 PM
noticed something strange just a little while ago coming back from a friends, its been raining in glasgow for days, car was all fogged up and damp so put on the front heated window to get rid of it and noticed it was even harder than usual to pull away from the lights so parked the car up and tested pulling away running the front and rear heated window with heaters on full.
pulling away in 1st gear its so weak that it almost stalls and cant get up past 10mph without some serious effort revs are low as well
when i say high revs i mean i need to get high revs through 1st and 2nd to beable to get it up to 30, i read elsewhere that in 4th gear and putting the foot down would be a good indicator of a worn clutch if the revs go high and the speed doesnt.
when i tried this both revs and speed rised steadily together but a hell of a slow
still reckon its the clutch ?
#4 mjt
mjt
    Serial Poster
  • Budding Enthusiast
  • 487 posts
  • Name: Mike
  • Ford Model: Focus Mk2.5 Zetec 1.8HE
Posted 22 July 2010 - 08:56 AM
Doesn't sound like it. Looks like you're suffering a serious loss of power. The vibration could be a misfire.
#5 mintalkin
mintalkin
  • PipPipPipPipPip
  • 3,543 posts
  • Name: mintalkin
  • Year: 2006
Posted 22 July 2010 - 10:17 AM
with the added info it may not be the clutch, does the engine rev with the car in neutral? any missfire or noises? if its missfireing could be plugs, leads or coilpack playing up.
#6 andy_1984
andy_1984
  • New Member
  • 131 posts
Posted 22 July 2010 - 10:27 AM
yeah it revs in nutral but rough (read on)
no misfires as far as i can tell then again i coudlnt tell as ive never experienced a misfire but there is vibrations from 1k to 2k revs in nutral then smoothes out a little after 2k revs
also feel vibrations when driving but that smoothes out once you get past 35mph
#7 andy_1984
andy_1984
  • New Member
  • 131 posts
Posted 22 July 2010 - 05:09 PM
just checked my spark plugs all were normal, exactly like this like this:
and heres the but;
2 were normal with miniscule amounts of carbon around the top of the spark plug body at the electrode end.
1 of the spark plugs insulator at the terminal end had cracked so i replaced this spark plug
1 was normal but looked slightly wet looking and dirtier than the others (couldnt replace never had £3)
with replacing the cracked one theres been no difference im still getting the same problem
ill replace the wet lookin one
noted another symptom to add to the list.
there are tiny juders every so often when accelerating, nothing major just little ones they are hardly noticable.
im going to get a full set tomorrow when i get paid and just be done with the lot as im not happy with the way the last spark plug looked.
are there any ways to check if its the coil pack or wires without having to replace them to see if its the culprit ?
#8 dezwez
dezwez
    Dezwez
  • PipPipPipPipPip
  • 5,064 posts
  • Name: Derek
  • Ford Model: ford focus 1.8 zetec mk 2.5
Posted 22 July 2010 - 05:59 PM
and heres the but;
could be the cat packed up had the same on a escort few years back
#9 jmurray01
  • 772 posts
  • Name: Jamie
  • Ford Model: Ford Fiesta Flight 3dr 1.3 Endura-E
  • Year: 2001
Posted 22 July 2010 - 06:40 PM
Could be the Alternator going bad. And the battery sending less power to the fuel pump as the battery gets low on power when too many electrical accessories are switched on.
#10 andy_1984
andy_1984
  • New Member
  • 131 posts
Posted 22 July 2010 - 06:44 PM
how would i find out if its the converter, gonna get my mates volt meter tomorrow and have a dig around with it
#11 dezwez
dezwez
    Dezwez
  • PipPipPipPipPip
  • 5,064 posts
  • Name: Derek
Posted 22 July 2010 - 06:51 PM
wait till its cold then give it a good shake should be no sound if ok .but if it rattles then its broke up in side
happen to me i was lucky to get over 35mph out of it hope this helps
#12 stef123
stef123
  • Management
  • 5,755 posts
  • Name: Stef
  • Ford Model: Mondeo ST TDCI
  • Year: 2006
Posted 22 July 2010 - 07:10 PM
im thinking its the coil pack/leads or plugs at fault here,
a slight judder occasionally when driving is a sure sign of a missfire.
i would recommend you replace all 4 plugs at a time. the slightly wet plug might also indicate this is the cylinder with the missifre...
most common cause of this is coil pack failure but bad leads or plugs can cause a coil pack to fail... but its not limited to these. a bad alternator or battery have also been known to damage coil packs (been there myself also)
#13 andy_1984
andy_1984
  • New Member
  • 131 posts
Posted 23 July 2010 - 09:38 AM
i reckon its now a misfire for sure, heard popping from the engine when accelerating .
how would i test the coil pack and leads totry and find which is the problem, money is tight right now id rather buy the coil pack at around 50 if i knew it was that rather than pay 25 for leads then not beable to buy the coil pack till next week :(
#14 andy_1984
andy_1984
  • New Member
  • 131 posts
Posted 23 July 2010 - 01:55 PM
was just checking the ht leads and with the engine running i pushed down on top of the lead that goes in to the coil pack, first two went ok then one of them i got a mild shock from one of them but cant remember as the shock went through the finger that wasnt pushing down on the lead i was pushing down on?. is this normal? i assumed all the rubber would be insulating you from getting a shock.
also engine management light started flashing now
#15 andy_1984
andy_1984
  • New Member
  • 131 posts
Posted 23 July 2010 - 09:18 PM
just changed ht leads and put full set of new spark plugs in and nothing has changed except the engine management light has stoped flashing
coil pack next then
Not what you're looking for?
