HI , GOT A 1.6 C MAX IT DOES NOT SEEM TO BLOW AIR THROUGH THE HEATER FAST , JUST WOUNDER IF THE POLEN FILTER IS GETTING BLOCKED . DOES ANY BODY KNOW WERE IT IS LOCATED SO I CAN CHECK IT ? THANKS RUSS
POLEN FILTER ?
Started by RUSSBUS, Sep 09 2008 08:39 AM
3 replies to this topic
#1
Posted 09 September 2008 - 08:39 AM
#2
Posted 09 September 2008 - 09:39 AM
i wouldnt think this would be the pollen filter stopping it but normally they are located behind the glove box. Can normally get to them underneath
#3
Posted 09 September 2008 - 12:44 PM
according to the book
Fitting Instructions
Where is the pollen filter?
centre - passenger side behind centre consule
Time to change - approx. 20 minutes
How Easy to change - lengthy
Fitting Stage 1:-
Remove the centre consule side panel in the passenger footwell. You may need to peel back the carpet slightly to gain less retricted access to the area behind the centre consule where the filter housing is.
Fitting Stage 2:-
The filter housing has a plastic rectangular access plate secured by screw at the bottom. You may need to partially disassemble ant duct components that obstruct access to this access plate. Once the plate is off the old filter should slide out easily
Fitting Stage 3:-
Once the plate is off the old filter should slide out easily, as it is designed with a flexible frame allowing it to bend round other components. Fit the new filter and refit the access plate and trim
Fitting Stage 1:-
Fitting Stage 2:-
Fitting Stage 3:-
#4
Posted 09 September 2008 - 01:29 PM
Why are fords different
Well thats my theory out the window!
