Nothing Works!
Lanna
 Share
Can anyone help?? The indicators and window wipers have stopped working the interior lights don't come on and the boot no longer opens, has a fuse went? Cars just a year old. Any help is much appreciated.
Lanna
Link to comment
Lanna
This may help:
FUSE SPECIFICATION CHART
Engine compartment fuse box
Ampere Circuits protected
Fuse rating
1 40 ABS module
1 30 ABS ESP module
2 60 Cooling system fan high speed
3 40 Cooling system fan
3 30 Cooling system fan low speed
4 30 Heater blower
5 60 Passenger compartment fuse box supply (battery)
6 30 Body control module (BCM)
7 60 Passenger compartment fuse box supply (ignition)
8 60 Glow plugs
9 60 Heated windscreen
10 - Not used
11 30 Starter relay
12 10 Main beam left-hand relay
13 10 Main beam right-hand relay
14 10 Dipped beam left-hand relay
15 10 Dipped beam right-hand relay, Powertrain control module (PCM), high and low cooling
16 15 fan
17 15 Heated oxygen (HEGO) sensors (Petrol engines)
17 20 Power supply module (Diesel engines)
18 10 Powertrain control module (PCM)
19 - Not used
20 - Not used
21 - Not used
22 15 Lighting control battery supply
23 15 Front fog lamps
24 15 Direction indicators
25 10 Daytime running lamps, Electric exterior mirrors switch, electric folding mirrors,
26 7.5 power window (driver's door)
27 7.5 PCM
28 20 ABS module, ESP
29 10 Air conditioning clutch
30 - Not used
31 - Not used
32 20 Horn, battery saver, keyless vehicle module
33 20 Heated rear window
34 20 Fuel pump relay, diesel fuel heater
35 - Not used
36 - Not used
37 - Not used
38 - Not used
39 - Not used
40 - Not used
Relay Circuits switched
R1 Cooling system fan
R2 Glow plugs
R3 PCM
R4 Main beam
R5 Dipped beam
R6 Daytime running lamps
R7 Engine cooling fan
R8 Starter
R9 Air conditioning clutch
R10 Front fog lamps
R11 Fuel pump, fuel heater
R12 Reverse lamp
R13 Heater blower
Passenger compartment fuse box - Type 1
Fuse Ampere rating Circuits protected
Ignition, rain sensor, heated
1 7.5 windscreen
2 10 Stop lamps
3 7.5 Reversing lamp
4 7.5 Headlamp levelling
5 20 Windscreen wipers
6 15 Rear window wiper
7 10 Washer pump, Parking aid (vehicles with
8 15 front parking aid)
9 10 Not used
10 7.5 Heated seats
11 - Not used
12 10 Airbag module, Ignition, electric power, assisted steering (EPAS), instrument cluster, passiveanti theft system (PATS), ABS
13 10 PCM, gear selector lever,
14 7.5 fuel pump, Audio system, instrument
15 7.5 cluster
16 7.5 Heated exterior mirror
17 15 Ignition switch
18 7.5 Instrument Cluster
19 15 Data link connector, Multi functional display, clock, internal scanner, heating ventilating, air conditioning (HVAC) panel
20 7.5
21 15 Audio system, bluetooth, Cigar lighter, front power
22 20 point
23 20 Trailer module
24 - Not used
25 30 Power windows (front)
26 - Not used
27 - Not used
R1 Ignition
Passenger compartment fuse box - Type 2
1 7.5 front screen
2 10 Stop lamps
9 10 Parking aid
10 7.5 Heated seats
11 - Not used
12 10 Airbag module, Ignition, electric power, assisted steering (EPAS), instrument cluster, passive anti theft system (PATS), ABS
15 7.5 cluster
18 7.5 Instrument cluster
19 15 Data link connector, Multi functional display, clock, internal scanner, HVAC panel
20 7.5
22 20 point
24 - Not used
26 - Not used
27 - Not used
28 - Not used
29 - Not used
30 - Not used
31 30 Power windows (rear) Heated windscreen, left
32 30 hand side Heated windscreen, right
33 30 hand side
34 20 Keyless entry
35 20 Keyless entry Rear power point, battery
36 15 saver Luggage compartment
37 15 auxiliary power point
38 - Not used
39 - Not used
40 - Not used
41 7.5 Ignition switch position 1
42 - Not used
43 - Not used
44 7.5 Ignition switch position 2
45 - Not used
46 - Not used
47 - Not used
48 - Not used
49 - Not used
R1 Ignition
R2 Power fold mirror 1
R3 Power fold mirror 2
R4 Not used
R5 Heated front screen
R6 Keyless entry (accessory)
R7 Keyless entry (ignition)
R8 Battery saver
R9 Not used
R10 Not used
R11 Not used
R12 Not used
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
