Rich99 Posted August 3, 2010 Share Posted August 3, 2010 I've just got a new S-Max with USB connection. Although the system can read the id3 tags, it appears to only let you browse by folder/filename. So, I arranged all my albums into the correct folders, and named all the tracks 'track#'-'trackname'.mp3. However it plays the tracks back in the 'wrong' number order - by which I mean it plays track 1, then tracks 10-19, then track 2 followed by tracks 20-29 etc. Is there any way to get it to play them back in the correct order, other than going through 9000 tracks & changing all the single digit track numbers to 01,02,03 etc? Thanks! Quote Link to comment Share on other sites More sharing options...
WillK Posted August 3, 2010 Share Posted August 3, 2010 I would imagine you need to put a leading 0 in all the file names. I use a program called Rename Master for these types of things. Should only take you about 5 minutes. Quote Link to comment Share on other sites More sharing options...
Rich99 Posted August 4, 2010 Author Share Posted August 4, 2010 I would imagine you need to put a leading 0 in all the file names. I use a program called Rename Master for these types of things. Should only take you about 5 minutes. Thanks for the recommendation, I'll give it a bash later on. Quote Link to comment Share on other sites More sharing options...
