Door Trim?
#1
Posted 07 August 2010 - 08:32 PM
My fiesta is 2003 (53) reg, what is the correct mark no??
Cheers
#2
Posted 08 August 2010 - 12:46 AM
a quick question, any help appreciated. Today the plastic column trim (not sure of correct name) came off the drivers side passenger door, and unfortunately was lost. What is the correct name for this?? I'm hoping I can buy one off ebay, but need to know the correct name.
Cheers
Your car is a Mk 6, and the Haynes manual for it is volume no. 4170, Apr 2002 to 2005. (02 - 54 reg.)
A quick 'phone call to your local breakers yard, and describe the problem, and colour of plastic part, and they will check around their stock, and 'phone back later. I get things from 200 miles away, at Overton Garage, Dyce, Aberdeen, paid by Credit Card, and sent to their local Depot at the edge of my town, for Saturday pick-up. Special post would cost extra. (mechanical/electrical parts get a warranty).
I presume you are referring to a triangular trim panel, that is to the rear of the glass, and just pushes into fixings; -- photo 12.13,in bodywork and fittings section, 11.9.
You could prise the other one off and ask the ford dealer for a price, but a colour match is worth having, as the door mirror controls will have the same colour bits.
#3
Posted 08 August 2010 - 08:16 AM
Do you mean the plastic trim at the front edge of the rear door, where the front and rear doors meet in the middle of the car? If so the trim part is the one that goes the full height of the window and is roughly rectangular in shape. It's quite common for these to come off on the Mk 6 (my 2002 1.4 diesel only has 1 of the 4 original trim pieces still on the car).
This part is a Ford Fiesta MK6 R/Hand Rear Door Moulding, Part Number 1473675 and I got mine from my local ford dealer at about £18 each new. The worst part about fitting them is getting the old clips off the car to clip the new part on. Also, they are only supplied in a black grainy finish so no worries about colour matching.
Hope this helps.
#4
Posted 08 August 2010 - 09:01 AM
Thank you
#5
Posted 20 August 2010 - 12:16 PM
Posted 20 August 2010 - 05:36 PM
#7
Posted 03 November 2010 - 10:27 AM
On my first attempt I pushed the 3 white clips into place first before I realised that the rim needed to fit over the door edge. As a result the trim wasn't flush - but fortunately I could unclip the fittings without breaking them, and I could start again.
#8
Posted 10 November 2010 - 02:35 PM
I wish I'd read this post a day earlier. I did the same thing today. Managed to forceably remove the old clips. Carefully lined up the new clips and fit the moulding to the door, making sure it was attached securely. Then when I stepped back from my handy work I saw that the trim was supposed to go over the edging first. Too late unfortunately as it was solidly attached. Now it sticks out half a cm at the back, very annoying.
#9
Posted 19 February 2012 - 04:07 PM
3 user(s) are reading this topic
0 members, 3 guests, 0 anonymous users
