Sign in to follow this
biggyn2
Help Please
need a little help please ,just brought a 2005 focus titaniun 1.6 and ive just notice the heater blower blows warm air even when its set to cool anyone know what could cause this to happen.....thanks for any help guys/girls
possibly the heater valve is faulty or the actual vents themselves do they blow according to the settings ie floor etc and can you feel the heater go from hot to cool when you turn the dial or does it stay the same if its the same then likely the wiring behind the dash or the heater control valve if its changing as you turn the dial then i can only suggest popping into a trusted garage or a ford garage and have it looked at
well the heater direction control doesnt seem to have much effect ie if i set it to blow on the main front vents it will still blow !Removed! hot air at my legs and it will still blow warm air from the face (front vents) and yes the temp of the air does seem to change when it feels like it without me changing anything on the controls sorry forgot to add the temp will change when i turn it up to hot but when i turn it to cool it will cool down but its still to warm thanks for any help
sounds very much like the heater control valve quite common on the fiestas and kas not so sure about the focus but definately the same symptoms £175 quid or less i believe to get the part and fitting from ford best call and ask
thanks m8 ill look into that ,any idea where on the car its located ill try to see if i can sort it out myself (im tight) lol
to be honest i dont know its location mate some cars have them some dont for some strange reason nip into halfords and open up one of there haynes manuals it should show you the location i tried google but came up with nowt
thanks artscot realy appriciate the help m8 im gonna be down halfords 1st thing robbing some knowledge lol ,!Removed! cars doing my head in now and ive only had it 3 days now and the aircon dont work :angry:
take it to kwik fit maybe it needs regassed if its not low they dont charge for it worth a try when it comes to airccon i always advise a mobile specialist so many sensors etc on them they can test them try yellow pages some do a free callout
i will try quick fit a friend took his there and they somehow sorted a fault without knowing it and didnt charge him lol result, p.s i think the heater control valve might be located under the scuttle panel under the wipers (might be wrong ) but i found a couple of bits that say its there
