Windows
#1
Posted 12 September 2008 - 06:54 PM
#2
Posted 12 September 2008 - 09:34 PM
#3
Posted 13 September 2008 - 01:03 AM
sounds like the global opening activated for some reason
What is global opening? it doesnt sound to helpful to be honest!
#4
Posted 13 September 2008 - 07:40 AM
Mintalkin -
"The global opening/closing feature allows all the power operated windows and power sunroof (where fitted) to be opened or closed; by pressing and holding either the lock or unlock button on the vehicle's remote key fob.
Open and close all windows and sunroof simultaneously at the touch of a button"
#5
Posted 13 September 2008 - 02:29 PM
#6
Posted 15 September 2008 - 12:45 PM
#7
Posted 27 December 2008 - 06:55 AM
#8
Posted 27 December 2008 - 12:27 PM
hi i've had the same thing happen twice. I went out in the morning after car had been locked up the night before to find both front electric windows fully open. I thought it must have been me the first time but when it happened again ...... I've got an LX so just the front windows are electric. I've also had a fault with the passeneger front window where if you open it then try to close it it starts opening again and takes about 5 goes to get it shut. It's been back to sandicliffe in Leicester 4 times and they stillhaven't fixed it. Keeps doing the same thing when I get it back. I think the faults must be linked. They did a central reset, adjusted something in the window, replaced the door controller - still the same. Any mechanics out there with any ideas?
Dont know about your problem but I dont think global closure has ever been fitted to a 5 door car where only the front windows are electrically operated and the back manual.
#9
Posted 10 January 2009 - 09:01 AM
Hi MontyMagic,
Have you checked for any foreign objects in the door rubbers?
The S-Max system is designed to have an anti-trap function. If the window senses a restriction of some kind it will reverse itself.
If that's all clear then you do have a problem with the motor.
HTH
Landman
#10
Posted 10 January 2009 - 12:55 PM
Hi MontyMagic,
HTH
Landman
Another theory - you have accidentally pushed the open button for several seconds (in your pocket for example) this triggers windows opening
