Windscreen Wiper Problem. Focus
8 replies to this topic
#1 focus nut
focus nut
    Newbie
  • New Member
  • Pip
  • 4 posts
  • Ford Model: focus zetec 02
Posted 24 August 2010 - 06:32 PM
I have a focus 02 model and when I press down the wiper lever to do one swipe and return it stops when I release the lever.
But if I hold it down it will carry on till I let it go.(works when held down,stops across the screen when let go)I have tried fitting another wiper motor & lever switch unit & have the same problem, Any suggestions...
Have something to contribute?
#2 artscot79
artscot79
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 7,995 posts
  • Name: arthur
  • Year: 2006
Posted 24 August 2010 - 06:43 PM
what happens when you push it up one click?pushed down it will do what you say push up one setting it will do it automatically
#3 H3lly
H3lly
  • New Member
  • 282 posts
  • Name: k
  • Ford Model: Mk1 Focus
  • Year: 2003
Posted 24 August 2010 - 07:00 PM
Wiper linkage.
#4 focus nut
focus nut
    Newbie
  • New Member
  • Pip
  • 4 posts
Posted 24 August 2010 - 07:01 PM
When I push the lever up to independant,speed 1 & 2 it works fine.
#5 tommy.h
tommy.h
  • Budding Enthusiast
  • 251 posts
  • Name: tom
  • Ford Model: mondeo 2.0 diesel mk4
  • Year: 2007
Posted 24 August 2010 - 07:04 PM
does it still self park when you turn off in positions 1&2?
tom
#6 focus nut
focus nut
    Newbie
  • New Member
  • Pip
  • 4 posts
Posted 24 August 2010 - 07:10 PM
No it does not self park when I turn it off from 1 & 2. I have to flick the lever down to park it or set it to independant...
#7 paramaniac
paramaniac
  • New Member
  • 121 posts
  • Ford Model: 2009 Focus Zetec S 1.8 Petrol
I had the exact same problem with my MK1 Focus. I never bothered to get it fixed because I got used to it, but an independent garage told me it was most likely to be the wiper motors which would need replacing. I seem to remember they were quite expensive so I put up with this "feature"!
#8 focus nut
focus nut
    Newbie
  • New Member
  • Pip
  • 4 posts
Posted 24 August 2010 - 07:13 PM
Yes I think I will have to put up with it to,as I have for the past year or so,I did try fitting a second hand motor & lever switch which I knew worked & had the same prob...Ian
#9 tommy.h
tommy.h
  • 251 posts
  • Name: tom
  • Year: 2007
Posted 24 August 2010 - 07:16 PM
Hi
there is a switch inside the motor that becomes dirty(this is the self parking mechanism) you need to take cover of the wiper unit and clean the switch.easy if you are quite good at DIY.
tom
Not what you're looking for?
